Wired audio connection
Hi everyone!
I just picked up a 2016 F Type R, and I was curious if there's a way to feed music from my iPhone to the car via a wired connection. I've tried plugging into both of the USB ports in the center armrest, and audio only seems to play via Bluetooth. While that's convenient, a digital connection would work best!
Thanks!
Aditya
Thanks!
Aditya
Ok, so I just picked up a '14 and my iPhone (11 Pro) works fine both USB wired and BT. (Even though it says it's reading my "ipod" ! )
Is your cable charging the phone when you plug it in to the USB?
Are you using a data compatible cable?
Have you plugged in another device -like a usb stick with music, to test reading from the USB port?
How can one proceed to trouble shoot without knowing what you have or haven' t tried.
Do what MK18 has suggested first then report back
