Wiring diagram
Meanwhile, try:
Dropbox Link
Nod to Dave on this one! Cheers.
DJS (07-05-2022)
Since you joined in 2016 I presume you have a pre-2016 f type. Shouldn't need to use reverse wire to trigger reverse camera ON any more with a carplay unit even though this is the default troubleshooting cop out.. Are you sure you have set your dipswitches correctly.. obviously if i am barking up the wrong tree just ignore everything I have just said.
Hi
I have the unique auto developments CarPlay, the car is 2017 model with the Jaguar Harmon system I have the dip switches in the right settings according to the
manual , they do say if camera is not shown to connect wire marked rear c to reverse light power wire. My friend has a the earlier model with the jaguar Bosch system
and his works ok.
and his works ok.
Check out the "How To" sticky for wiring diagram, maintenance manual, and much more.
Meanwhile, try:
Dropbox Link
Meanwhile, try:
Dropbox Link
Ok, so I don't have an F-Type but I do have an F-Pace SVR so I lurk in this forum since the F-Pace forum is in a coma (always).
Does anybody know where I can get such documentation/wiring diagrams for a 2021 F Pace?
Any pointers will be appreciated.
