Is it worth it to upgrade the Meridian audio system?
Lol so I took a pretty women for a ride in my car and she loved everything about it but asked basically what was wrong with the audio, it was at that point I realized her GMC S.U.V. had a more tollerable sound system then my car. I have looked through the forums and at some youtube videos on how to upgrade the system and seen that it's possible.
Basically I am curious if any of you have upgraded your audio and if so how much did it cost, and are you glad you did it? I really would like a better sound system but I don't know if I could stomach spending more than $3,000 maybe $4,000 if I could get something truly epic that made me feal like I was sitting in a theatre or something hahahahahaha.
Also do you guys think an audio upgrade would void any warranties? I know the audio wouldnt be covered anymore but would it maybe void other electronic components also?
I don’t personally think that it’s worth the upgrade. While the Meridian is not good, I’ve heard worse. Also for the convertible audio is harder than the coupe and quite frankly the car itself is the best audio. A big problem with the Meridian are the speakers, they are just not high quality and tend to vibrate despite the proposed fixes. Replacing those might help a little but the cost of replacing the entire system is likely not worth ROI on a 2014 Ftype to begin with, Once the top is down the sound system quality gets drowned out by road and wind noise anyway.
We that’s my view for what it’s worth.
I have the upgraded 770Watt Meridian in my F-Type R and it's actually pretty decent certainly not as good as some of my previous M cars, or Harmon Kardon systems in former or current vehicles, but it definitely doesn't suck.. I'd be hesitant to go messing with a factory system in an F-Type regardless unless you just don't care, have money to burn and REALLY trust your audio installer.. Lol..
mtstaterebel (07-07-2020)
Received 3,226 Likes
I leave it on Meridian surround sound all the time and I have all the settings smack in the middle except for the sub which I have dialled back a notch as even in the middle the sub is a bit too doof doof for my liking!
It's at least as good if not a bit better that the B+W was, and that's in a coupe vs a four door sedan.
Michael211 (03-24-2024)
I just adjust it to my liking and its background when the wife and I are out for a ride anyway. It is a drawback of these cars if you put alot of stock into agood sound system.
I have the 770. As someone who recently spent $700 on a carplay interface, I can be described as someone who *cares* about the system in my car.
If you're talking about upgrading to the factory Meridian 770 system, I wouldn't bother, unless you're getting parts for cheap/free and want a project (i.e., your time can be considered free). It's at best a decent to good system. Not great.
If you're talking about non-factory upgrades, I suspect you'll be putting a *lot* of money into it to get a "good" system, and there are much more interesting things to put that money towards.
The 770 watt Meridian Surround sounds good to me, especially from high resolution sources such as CD.
I’ve noticed on my system some songs sound excellent but most sound like crap with a tinny bass rattle at normal volumes. And of the songs that sound like crap, sometimes the sound quality actually improves by turning up the volume.
I did a quick frequency scan with a phone app and there seems to be a funkified resonance at around 80 HZ. I tried a couple songs where I had sucked out the 80 HZ band but it didn’t seem to help much. Perhaps a more diligent execution of this idea might yield better results.
I’m reasonably convinced the actual hardware is fine and the main problem is in the EQ profiles loaded into the processor/ amps.
Oh mighty Unhingd, could you share detail on the software upgrade you had done? Where and when done? Description, bulletin or software version used for it, etc.
The software update was a fix for the tweeter channels getting unwanted frequencies. Supposedly early 'verts had a problem along those lines. I had mine updated for giggles but it didn’t change the tune of the system much.
The problem with the F Type’s sound is the F Type. Or maybe Meridians’ tune for the F Type. The sound in my other Jags is perfectly acceptable. The F Type is just awful. But, to make a significant difference you need to be able to change the tune and the subwoofer assembly at the minimum.
Carbuff2 (03-25-2024)
