Wow Jaguar....Stereo all fixed finally!!
#101
Received 3,252 Likes
Thanks for the bulletin Cap'n Ham!
I'm taking the car in this arvo to get the supercharger rattle fixed tomorrow, so I might ask about this while I'm at it.
My car meets all the criteria - MY2015 coupe with the 700W system, VIN in the range - so they might agree to do it.
Question for Cambo - as you know I don't appear to have any real problem with my sound system, and if there is any buzzing from the tweeters it only appears if/when I crank the sound way up to painful level (and even then it seems to me it's speaker/cover panel rattle caused by the sheer volume). So is it worth getting this fix done anyway, I can't see it causing any problem and you never know it just might improve the sound?
#102
I can't say I noticed the buzzing but maybe my music doesn't provoke it. I got my dealer to do it anyway while they had it on the lift. Allegedly it also corrects the "missing" audio profile for the coupe - I think that's supposed to mean the early coupes audio units were programmed as though they were in a convertible...
My ears probably aren't tuned enough to know what differences there should be with having a non-removable roof but maybe the Jaguar boffins figured something out. Maybe that was the root cause behind the buzzing. I still would like to see them implement a more controllable variable gain for speed. I do find I have to twiddle with the volume far too much...especially now I have discovered the unholy combination of Dynamic and Sport modes....
#103
My dealer applied the "JTB00537NAS2" fix yesterday...
Initial thoughts:
Overall impression: Sound noticeably improved, especially mid-range. The highs seem cleaner/crisper too. You might be a little disappointed if you're looking for a "knock-your-socks-off" renewed experience; but, the sound is richer, at least to my amateur audiophile's ears. [Note: I'm still running all of my R's OEM sound components.]
After-fix adjustments I made:
>Treble setting was turned up all the way before the fix, and I ended up leaving it there. I played with the Bass setting, ending up at about 3/4. Same setting with the Subwoofer. I did make a change to my Surround setting. Prior to the fix, I had always found DTS worked best. Now I prefer the Dolby setting.
>Balance/Fader: I left side-to-side in its middle setting, but ended up adjusting the fader bias two "clicks" towards the rear (previously had left in the middle setting).
Your SA may have trouble accessing the JTB00537NAS2 tech bulletin if you give them Reference No: SSM73060. (I originally sent my dealer reference to SSM73060, but since my SA was also a tech previously, he was able to track down JTB00537NAS2. He suggested just forgetting making any reference to SSM73060 and instead reference JTB00537NAS2 now that it has been created in the system.
Finally, FWIW, the tech bulletin references the "Meridian 700W" sound, not the "Meridian 770W Sound System." Oh, well.
Initial thoughts:
#104
If you can set your treble and bass with that high of a setting your stereo is light years ahead of my yet to be fixed unit. Amazing how challenging it is to for technicians to find these tsb's. Are they secretly posted by JLR so they can't be found? I have an electronic storage system for files in my business. I can search thousands of files using one or two key words in minutes. Baffling.
#105
Initial thoughts:
Initial thoughts:
My experience after the "fix" was a POS sound! Everything sounds muffled, as if Kim Jong-nam was trying to shout with a poisoned cloth over his mouth, suffocating him. I've changed from sound mode to sound mode, and the dreaded cranking up the bass, mid, and treble just to hear your music in all its glory was sad, Sad, SAd, and more SAD, to me. In fact, I much prefer the rattling over this rear naked choke on the sonic frequency. So now, another big disappointment with JLR and more expletives to myself!
#106
NTAV (02-19-2017)
#107
Just as a point of reference, I am experiencing this issue with the tweeters and brought the car to the dealership to have the software fix applied (along with several other unrelated issues addressed). Even after describing the exact same symptoms from the TSB and giving them the TSB number, they still fiddled with all my stereo settings and told me "everything's fine, it's your settings and the volume level you're using" without applying the fix at all.
![Mad](https://www.jaguarforums.com/forum/images/smilies/mad.gif)
#108
Originally Posted by Inspector-G
Just as a point of reference, I am experiencing this issue with the tweeters and brought the car to the dealership to have the software fix applied (along with several other unrelated issues addressed). Even after describing the exact same symptoms from the TSB and giving them the TSB number, they still fiddled with all my stereo settings and told me "everything's fine, it's your settings and the volume level you're using" without applying the fix at all. ![Mad](https://www.jaguarforums.com/forum/images/smilies/mad.gif)
#109
#110
Just thought I'd share my experience - just got a 2017 base coupe. I don't have any of the problems discussed in this thread. After playing with it for some time, I'm happy enough with the sound that I may not upgrade it (my home system uses studio monitors and I've been an audiophile for 50 years, played in a band, and so on).
I thought the Dolby setting sounded cleanest and adjusted the tone controls to match that. I ended up with the base and treble flat and the sub up four clicks. I adjusted the sound map one click left (???) of center and moved the sound stage forward to the back end of the windshield. BTW, it sounds a lot better when you crank it a little. 80 db seems to lack a little bit of bass. Get it up to 95 db or so, and it starts to rock.
I hope that you guys adjusting everything way up - treble, bass - listen to what you're doing to your frequency response. Making big adjustments to the tone controls usually make big holes in the frequency response somewhere.
BTW, cymbals are not a lead instrument, but you'd think so if you listened to some of the stereos I've heard... Listen to some live music, then immediately go to your car and adjust it to sound like that.
Misujerr (02-26-2017)
#111
1. - A load of crap!
2. - Shameful on this dealership part
3. - Do they think you are stupid......, unacceptable service.
4. - They should be reported for this idiot behavior and response.
OK, now I feel better. Good Lord!!!!
#112
I'm searched but haven't found it on this forum yet... I have a 2015 F Type R and I had the dealer apply the audio TSB that's mentioned in this thread (thank you, everyone). How do I check the version to verify the dealer actually applied the update?
I saw mention of a version (e.g. 5636) for InControl Apps but I don't believe my year has the app integration. The dealer seemed hesitant to apply the TSB so I want to ensure they did what they said they would do. Thanks!
#113
I agree the Meridian sounds like crap. I miss the 1200-watt Bowers & Wilkins in my XJ. So anyway, I'm going to the dealership today for an early oil change. I'm gonna ask them about the software update for the Meridian. Thanks for the 411!
#114
Remember, don't take "no for an answer", or the settings excuse 101 as a cause either. The fix is real, sounds great and if anything else, laziness or incomp. (I hope not the latter) can't become issue from the service dept.!!!
sgvkirbster (03-01-2017)
#115
#116
Just had the firmware update for the stereo done today. The service manager said the tech couldn't hear an issue (he was listening to a weak FM station apparently). The service writer had him do it anyway (a different service writer at the same dealership would have never done that). It does sound allot more balanced and much more tolerable. Like @sgvkirbster alluded to, it sounds better but is not how I would imagine a top of the line car stereo sounding... it is more balanced sound but not very crisp. No annoying buzzing which is nice.
sgvkirbster (03-06-2017)
#117
#118
I usually listen to mine in stereo mode since it seems most all the sound, previous to the update, came from the center speaker in other modes. With the FW update, Meridian sounds better than before, but still prefer stereo than the surround modes for music.
#119
I didn't know WTF I was missing out on. Music is now coming from all the speakers instead of primarily from the tweeters and subwoofers. Sooo much better. When I brought the car in, they had no idea what I was talking about and said they needed to keep the car and research the issue. When I handed them a copy of the full JTB, the service manager took it to the tech. In typical fashion for this dealer, no further questions asked. They just did it, and even they remarked how much better the system sounded. Took exactly 1hour from driving in to driving out.
#120
