Wrench lodged deep within Driver Seat track - Help
Tonight I made the mistake of getting in the car with change in my (right) pocket, and naturally half of it fell out the instant I got situated behind the wheel. I used a small open-ended wrench to file all of the change out but lost hold of damn wrench into the track. As far as I can tell it’s wedged somewhere in the center portion of the track and it is unfortunately preventing the seat from moving completely back, coming roughly 3in short of where it should otherwise meet the rear cowel. It’s not in a position where i can see it or feel it anymore. And I am unable to drive the car with the limited seating position. Needless to say it’s time to panic. ![Icon Eek](https://www.jaguarforums.com/forum/images/smilies/icon_eek.gif)
What do I do? I may have to take the seat apart in pieces from the top down. It’s that serious
My car is different but the driver seat is held in place by just 4 screws. Two at the rear and of the tracks and two at the front end.
If yours is similar or the same I am sure you will see the ones on the rear but if you cannot move the seat back far enough you may or may not see the ones at the front.
If you can you would be able to unscrew them and lift the seat up maybe making access easier.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Received 3,209 Likes
Maybe you can poke a piece of strong wire in along the runner and flip the wrench up and out?
Do it by feel or at a stretch use a "mechanics" mirror (I have one) to see what you are doing.
I have used old wire coat hangers cut and bent to shape for things like this in the past, but can you still get those wire coat hangers these days?
Still worth a try though!
And yes raising the seat as high as it will go should help with access.
Don't forget that has been suggested plus I think it is the wrench thats causing the problem and not so much the family fortune.
The point I am making is that the bolts on my seat can be accessed by feel and with the correct tools can be undone even if the seat is hiding them from view especially if the seat is raised as high as possible.
Unless of course the OP's seat tracks are so very different.
I wonder if the seat is raised as high as possible if the forward and rearward movement increases?
Sorry to hear that.
If I were in that position I would undo the bolts that I could see whichever end it is and then forcibly bend the seat and rails as far as it takes to see the wrench and get it out.
Then bend the seat back as far as possible to original and see if it moves forward enough to expose the rear bolts to take them out.
The seat itself is extremely expensive but I would think the rail/tracks are a good bit less expensive??
+1 on that.
In my workshop manual it "talks" about removing the seat cover as if you can do that without taking the seat out. You have to take off some trim pieces. It is not very clear at all but you might look to see if you can do that.
Disconnect the battery tho while attempting any of this.
+1 on that.
I appreciate all the suggestions, I’m trying everything.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/p1070014_465c7459c08d15bd639fb0de7b46927988984670.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/p1070015_b4861c00ddb33247c11aad2b4b9a2411c3c7be14.jpg)
https://video.search.yahoo.com/searc...6&action=click
The pesron has the seat out but you can see how the cover is attached.
Have a look at the above. It might give you an idea. My workshop manual is really no help as it just shows a picture with what looks like velcro under the rear of the seat.
You will have to feel around to see if there are detachable "items".
I added a couple of pics of my passenger seat. I was able to pull forward on that long plastic retainer under the very front edge of the seat and when that came off the whole front section of the seat cover is quite loose.
You would have to taken the control buttons cover off to get the side section loose but it looks like that would pull off in some direction as many such covers do. Not sure on that.
Under neath the cover would be foam. Not at all sure how you would deal with that.
