ZF8 HP70 solution for upcoming Velocityap build.
Hello everyone,
The reason for this post is to inform members that are planning to invest in the upcoming AJ133 VelocityAP engine/supercharger/e85 build of additional options. Stuart and his team are working on a bottom end solution (sleeved/semi closed block) for those wanting the most out of their build.
Most forum members are aware that our transmission will need to be addressed. After discussing my personal project goals with Pure drivetrain solutions, they have agreed and are willing to build my ZF 8HP70. See discussion below.
I will warn everyone that the stage two transmission with upgraded torque converter is not budget friendly being right under 15k however, the end product is a fully built transmission capable to withstand 1400hp and 1000-foot pounds of torque. Pure’s stage two transmission would provide a path to a 1000whp F-type.
Hi Philip,
We'd be more than happy to get a build going for your 8HP70, the stage 2 and torque converter upgrade would be a solid choice for your setup.
Where are you located? Would you be able to send in your transmission to us to rebuild?
Thanks for reaching out, looking forward to hearing from you.
- Eric @ PDS
Pure Drivetrain Solutions
27 Industrial Blvd, Medford NY 11763
www.puredrivetrainsolutions.com
The new standard in drivetrain components
On Tue, Feb 21, 2023 at 4:58 PM Squarespace <form-submission@squarespace.info> wrote:
Sent via form submission from Pure Drivetrain Solutions
Name: philip brousseau
Email: philip.brousseau@yahoo.com
Subject: F-type R performance ZF HP70
Message: All,
I recently viewed one of the videos that your team has placed on YouTube as well as reading through various forums where enthusiast have used your products. From my research Pure is the market leader in regard to building a performance ZF transmission.
If your team is willing, I would like to send my Jaguar F-type R ZF8 HP70 transmission or the car itself if needed for a stage two rebuild and torque converter upgrade. The goal of the engine project is to have around 1k whp.
Velocityap has just released a cp Carrillo piston and rod package for the AJ133 and is currently working with Darton/LA sleeve to increase block strength. The engine will be fitted with a TVS 2650 blower running on e85 however, as you are aware the jaguar F-type transmission is rated for 700 engine hp.
Please consider and thank you for your time.
Philip Brousseau
Hi Philip,
- Eric @ PDS
Message: All,
Philip Brousseau
The following 2 users liked this post by pab74:
Panthro (12-14-2023),
TheDrainPlug (02-25-2023)
Hello everyone,
Hi Philip,
- Eric @ PDS
Message: All,
Philip Brousseau
Hi Philip,
- Eric @ PDS
Message: All,
Philip Brousseau
