1960 Mk IX brakes lock up
My MkIX brake pedal hardens and all 4 brakes lock up when driving. I replaced the booster with a universal part from XKS unlimited and a rebuild kit for the master cylinder. I even bypassed the hill holder with a new brake line. On the lift, as soon as vacuum is applied to the new booster, the brakes again lock and the only way to release them is to crack the hydraulic line going from the booster to the brakes. There deosn't look tobe another part in the system that could be causeing all 4 brakes to lock at the same time. Could I have received a bad (new) booster from XKS? Any suggestions would be appreciated!!
pauldellaira (05-08-2017)
This might be completely irrelevant but years ago I had an old Wolseley ( no power brakes) and the brakes locked themselves on one day, rock hard pedal and drums all hot. Like you I had to crack a nipple to release the pressure. Problem was the little hole in the master cylinder that allows fluid back into the reservoir when the pedal is released was blocked. Might be worth a look.
Good luck
Good luck
