2000 XJ8 cooling system
I don't believe the version of JTIS21 has information on 2000 V8 engine except renewing an oil pressure switch. If it does I can not find it. There is on tool bar toward the left a red explanation point that says new under it. When I click on it a list of items including engine comes up but nothing happens when I click on cooling which is 303-3. I have a cooling system leak that I can not find. The coolant recovery tank has very little fluid in it and I have renewed the filler cap on expansion tank.
Thanks for your reply. Unfortunately your answer did not solve my problem. I did as you said entering year 2000 XJ8 and nothing in sec. 303 engine cooling came up. Same was true for years 2001-03 except however I entered 2004 everything in sec 303 including cooling came up. That is why I believe I do not have in this version of JTIS 21 the information I am looking for. The 2004 XJ8 appears to be similar but not exactly the same as the 2000. Suggestions please.
There is nothing for the XJ 2000 & 1999 MY because there weren't any changes.Use the 1998 section.
Wes Steenrod
09-06-2015 06:52 PM
