2009 Jaguar XF suddenly won’t start (no power) after drive
My Jaguar has an unresolved issue that I need direction on. If you will, the vehicle suddenly started giving me a message stating that the key fob was not found in slot. Then it started running a little sluggish at a light one day. I put the car in park and back in drive and it was good. The alternator was replaced one year ago with the factory Bosch battery ($350). I drove the car one day and when I got out of it and went to lock the doors and there was no power. I gave power to the vehicle and ran a quick scan and it only gave a Battery and Steering Sensor error code. Nothing about the Body Control Modul or the Central Junction Box. Any idea what the issue could be and what’s the DIY resolution that actually works?
I've just removed one of your posts from Jaguar Forums Feedback & Suggestion Centre forum because it is not for technical questions. The General Tech Help forum is also not the best place to post technical questions about your model. Please post technical questions in X250 forum in future:
https://www.jaguarforums.com/forum/xf-xfr-x250-44/
When asking questions about error codes, the best approach is to post the actual codes and not just descriptions.
You will get a lot of help from knowledgeable and experienced members if you post in the right place and give as much information on an issue as possible.
My mechanic used his scanner and it only showed the Batter and The steering Sensor as faulted error codes. Not sure if I can get him ti retrieve that info.
can’t imagine either of them Failing that soon. The Batter is a factory suggested BOSCH $350
Beezalino
XF (X260)
06-08-2023 06:54 AM
CarlD
03-06-2023 02:41 AM
wdesign
05-08-2018 09:25 AM
