2015 F-type
- Set the ignition to the ON position.
- Open the hood.
- Open the drivers door.
- NOTE:If the accelerator pedal pressed before the brake pedal this will cause Brake Over Accelerator (BOA) logic and will default the accelerator pedal to 0%. If this happens the service reset procedure will have to be restarted.
Fully depress the brake pedal then the accelerator pedal and hold for 10 seconds. - A 'Service Reset' message will appear on the instrument cluster.
- Release the accelerator and brake pedals and set the ignition to the OFF position.
- Set the ignition to the ON position and check the message has been cleared.
- If the message remains, repeat the process.
Refgthl (11-12-2020)
PolkNole
04-12-2020 11:26 PM
doctordeuce
02-28-2015 07:19 AM
