2017 XJL Battery Charging
Received 3,887 Likes
Chuckmeister, check out https://www.jaguarforums.com/forum/x...-power-241729/. That should have a few ideas for you. The big thing is you need to invest in a CTEK battery maintainer. This device is not a standard battery charger per se, but something that gives a small trickle charge to the battery every now and then. That will solve your issue. The big thing is just remembering to unplug the unit before driving off.
Scott Bourne
12-03-2017 11:07 AM
