4.0 timing tools,where I can rent them or can I borrow them from someone?
I'm looking to borrow or rent the jag 4.0 timing tools so I don't have to buy them. Anyone have any ideas where I may be able to do this. Or perhaps from someone on here. I may be open to purchasing a used set as well. ![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Thanks for the help!
Not sure if you found the tools you need, but in the event you have not, I offer a suggestion. You run an auto auction, so you probably know a few Ford/Lincoln guys, right? Ask them if they can loan you the timing tools for the Ford Thunderbird/Lincoln LS. Same engine, same timing tool, same part number as the Jag tool. I did that recently through a friend of a friend. Got the whole kit in an unopened box for the cost of a large bottle of Crown Royal. If the dealer(s) there are like the one here, they will have never used them, or only rarely, so they will be less hesitant to loan them out. Beats paying high dollar special tool costs or going through the hassle of fabricating your own tools.
Hopefully you get both the tools and the help. But, all you really need are the tools. You can do the job yourself. If you can't get the tools, you can make them pretty easily. Just need a sturdy metal bar, drill 2 holes, a couple of spacers and bolts, homemade tool. I made one to help re-set the timing after I had returned the tools and then swapped engines. Used angle iron to help prevent flex and also used a 5/8" x 2" bolt in place of the flywheel setting plug. The 5/8" bolt was not perfect, but prevented most movement. The crankshaft still moved slightly, so the bolt acted more as a visual aid to check the flywheel position after each step of setting the cam timing to insure it had not shifted. I learned that if you do the camshaft procedure correctly, the crankshaft won't really move anyway, but it helps to have the opposite cam locked, too.
Let us know how it works out.
Wolfy
05-28-2024 08:06 AM
philwarner
09-05-2015 10:05 AM
