6 years old gas in the tank.. crank no start..
Old 03-29-2017, 06:01 PM
Xjr400hp's Avatar
Default 6 years old gas in the tank.. crank no start..
Hello hello! I parked my 98 xjr 7 years ago coz I found out that one of my timing chain glide cracked. Finally found time and finish full timing tuneup including spark plugs.
Now I'm trying to start the car after 7 years with the same gas what I had in the car when I parked.(I did put additives when parked) It did hesitate for a second but thats all...
. I can hear fuel pump and injectors but no start..
Need help. Where to start. ☹️☹️
Old 03-29-2017, 06:41 PM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Give it the best chance - drain the tank, put some fresh fuel in and bleed it through to the rail.
Old 03-29-2017, 08:00 PM
Ranchero50's Avatar
Ditto. I've been known to pop a fuel line off and jump out the fuel pump relay so it pumps the old stinky stuff out. Then give it 5 gallons at a time of good stuff so it can make the sediment solvent again a little at a time. Might also need to change the fuel filter if the old stuff was really rank.
Old 03-29-2017, 08:29 PM
Xjr400hp's Avatar
Thanks! Exactly !! I about to replace fuel filter and now it's okay to jump the relay, but then how to leak the line going towards injectors?
Old 03-30-2017, 02:27 AM
GGG is offline
You could drain it at the schrader valve on the fuel rail. Same spillage precautions as for changing a fuel filter.
Old 03-30-2017, 08:41 AM
Xjr400hp's Avatar
I already broke both of my engine mounts, now I'm not doing anything without a good advise, thanks guys.
Btw is it ok to jump fuel replay and bring the tank to run dry then refuel it with the new one? I don't want to damage the fuel pump by running dry, coz that would a messy job ��
Old 03-30-2017, 11:03 AM
Ranchero50's Avatar
It's similar to contaminated oil. You are going to get as much out of the engine as possible and then change the oil after a short amount of time. Ideally you want to dilute the bad stuff with the good until it doesn't matter.
