Adding jag coolant/antifreeze
Received 3,887 Likes
M_Arq, the bottle should have instructions on it as to how to add the mix. If you are only adding a quart/liter of coolant, then I would add just what is in the bottle and go from there. Worst case the coolant is a little more of the antifreeze than water, but in the big scheme of things, it will all be ok. That will ensure you don't hurt the engine by overheating it.
To confirm the advice given above, here's the relevant extract from the Owner's handbook:
![Adding jag coolant/antifreeze-coolant.jpg](https://www.jaguarforums.com/forum/attachments/general-tech-help-7/63609d1480970486t-adding-jag-coolant-antifreeze-coolant.jpg)
The critical thing is to use the correct Extended Life Coolant specification. At least this information does still appear on the Jaguar 5L and 1L coolant containers.
M_Arq (11-22-2013)
Wolfy
05-28-2024 08:06 AM
