AIR TEMP on HIGHER BOOS
Old 08-29-2018, 02:41 PM
Alsaropolis's Avatar
Default AIR TEMP on HIGHER BOOS
Ok, so if one gets bigger and smaller puleys and spins the Jag chargers faster , one gets more heat....... OK
1. What is good air temperature of air feeding engine....
2. What is TOO HOT,, ?
jaguar seems to have the intercooler linked to normal radiator, which means it dosent cool that well,
am in procces of fixing additional after coolers, fans , and extar cuirculation pump, but would appreciate what temp. one should aim for .....
thanx
alex
Old 08-29-2018, 02:56 PM
Old 08-29-2018, 02:57 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
For the benefit of members without ouija boards or crystal *****, the Jaguar in question could be a 2011 XFR.
avern1 (08-29-2018)
Old 08-29-2018, 04:46 PM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
Those sorts of changes ought to help a little, although if it's using a maxed-out supercharger then not much.
Changing the SC is the way to go in that case.
Old 09-14-2018, 06:49 AM
Paul_59's Avatar
Banned
Not sure what would be considered too high an inlet air temperature, (IAT) the higher the temperature especially at higher boost pressure the greater the danger of detonation occurring and the ECU taking action to prevent or react to this, usually by retarding ignition timing and boost which will protect engine but reduce power output whilst the conditions remain.
Optimum inlet air temperature (IAT) is easier to specify, the closer to ambient air temperature the better, or if you're really serious and have inclination and money then refrigeration / air conditioning to get temperature below ambient especially in hot summer conditions will significantly help with increased power (or avoid power reductions due to high IAT)
Old 10-10-2018, 11:37 PM
scottjh9's Avatar
From what i have read 135 degrees F or less entering the cylinders
XJ8JR
03-02-2022 10:08 AM
ianritchie
08-22-2017 12:15 AM
webbeing
04-19-2016 10:41 AM
Ophitoxaemia
02-04-2015 11:22 PM
Jag-Nut
03-14-2013 08:49 PM
Quick Reply: AIR TEMP on HIGHER BOOS
