Ajv8..engine swap
Received 3,929 Likes
I would recommend going with an aftermarket ECU (see what Holley has available). That is going to simplify a lot of things and make a lot of errors just not happen. If you attempt the jaguar ECU, then you are going to be trying to make ABS sensors work on the wheels, will need a bunch of other modules, etc. Pretty much, you will need a whole wiring harness and all the sensors from that year car to not have a laundry list of error codes. Not to mention, the aftermarket ECU is going to come with its own screen to give you all the engine vitals where you would end up having to take the Jaguar instrument cluster and attempt to make it fit into your car. Yes, these ECU's are around a $1000, but I think you are going to be money ahead in what you save with having to get all the other parts and just time in making it all work.
WTB[SouthWest]: Wanted, 4.0 Supercharged v8 engine or donor car
Bluecortina76
09-17-2017 01:43 PM
soonerpride316
11-05-2010 08:43 AM
