Alarm reset - 1997 XJR6
Hi guys I was looking through the how to do section on car alarm reset, I own a 1997 jag xjr but I couldn't find the instructions for that model!? The nearest was xj6 x300 is that the same reset instructions as the xjr? Many thanx and regards mark.
Last edited by GGG; 07-30-2012 at 05:54 AM. Reason: add model detail to thread title
Mark,
1997 was the cross over year so you could have either a straight 6 (X300) or a V8 (X308).
You mention finding the XJ6 X300 so it sounds like you've got the S/C straight 6. If so, the reset is the same on the N/A and S/C models.
Please add vehicle details to your Signature to help others to give relevant advice. Go to the User ID button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Alarm reset is closer to Black Magic than Science! Never understood why Jaguar have so many different procedures across the model range.
As you only have the one remote / fob, you only need to carry out the instructions once. If you later get hold of another remote as a spare, you'll need to go through the whole reset procedure again with BOTH remotes.
baskervillema
10-01-2015 06:43 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
