Aluminium furring
Presuming you only want to clean the rough casting and not polish the surface, the usual trade method is a wash product containing dilute phosphoric acid applied with a hot or cold pressure washer.
However, any of the "non acid" alloy wheel cleaning products for the DIY market should do the job. I use Sonax Wheel Cleaner.
Spray on, agitate with a brush and hose off.
Gerard (03-21-2019)
Autoglym do an Alloy Wheel Protector aerosol. I haven't used it so can't offer an opinion on the effectiveness but it should offer temporary protection. The problem is the transmission casing will always be subject to water spray so If you want a permanent seal to prevent oxidation, an aerosol Clear Coat is probably a better option.
As I recall from my XJ40, the transmission casing is quite a rough finish so once thoroughly cleaned, a clear coat should adhere without any additional preparation.
I took this out to replace a faulty torque convertor. Three weeks later, the transmission front seal failed and I had to do it all over again!
fergs03R
09-16-2011 07:22 PM
exexpat
12-20-2010 04:25 PM
