anyone have 1st hand experience with Fidelity extended warranty?
Like the title says, looking to see if anyone has first hand experience with Fidelty Extended Warranty plans? I read a lot of mixed reviews on-line, and some threads on this forum too, and the consensus is everything from "its worthless" to "it covered $25k in repairs."
Looking to purchase the Platinum coverage, which is an exclusionary plan.
From their website:
PLATINUM coverage plan
In addition to offering the same features of Powertrain, Silver, Gold, and Gold Plus, Platinum expands to cover almost all assemblies of your vehicle, giving you the “Ultimate Peace of Mind” protection.
Platinum Exclusions
UNDER PLATINUM COVERAGE, ANY OF THE FOLLOWING PARTS ARE EXCLUDED:
Brake linings, brake drums and rotors, disc brake pads, standard transmission clutch components and assemblies, air bags, solar powered devices, hinges, glass, lenses, sealed beams, body parts and/or panels, trim, moldings, door handles, lock cylinders, tires, wheels, all batteries except Hybrid/EV/High Voltage batteries as listed under Silver Coverage Plan, light bulbs, upholstery, paint, bright metal, freeze plugs, heater and radiator hoses, exhaust system, shock absorbers, audio/security or other systems not factory installed, work such as front-end alignment or wheel balancing, constant velocity joint boots, safety restraint systems, cellular phones, radar detectors, appliances, or vinyl and convertible tops.
Discuss.
From their website:
Platinum Exclusions
Discuss.
supercat'dXKR (03-20-2015)
Well, thats what an exclusionary policy means. If it IS on that short list, it's not covered. If it's NOT on the list, you're in the safe.
I'm not sure that's correct Super - consider the situation where a (not covered) heater hose bursts, and 30 seconds later the oil boils and destroys the engine. My interpretation is that you are NOT covered (and you can bet the insurance company will say the same). Instead of paying them, put some money in a 'disaster pot'. If it's still there at Xmas - spend it on the kids!
I currently have the Fidelity EW under the Gold plan, I would have loved to get the Platinum level but it was $10k for my 2007 XKR. I have had NO issues with them covering repairs. I have had the following replaced/repaired by them.
Rear Main Seal
Rear Passenger Axle Seal (twice now), they covered the "service" of the rear diff each time too.
Thermostat
They didn't argue with any of it and the Rear Main Seal was a $2400 fix. They send out an inspector, he signs off and the repairs are done and I pay my $100 deductable.
Fidelity is the preferred and ONLY Extended Warranty approved by Lincoln, Cadillac etc. CPO coverage.
Rear Main Seal
Thermostat
Rear Main Seal
Thermostat
Rear Main Seal
Thermostat
$10k for the platinum level is double than what it goes for. Shop around, you can buy the coverage from any dealership, so you can walk into a Toyota dealer and buy it from there. I'm sure buying it from the Jag dealer would come with a Jag style markup.
From their website:
Platinum Exclusions
Discuss.
From their website:
Platinum Exclusions
Discuss.
I would NOT buy a car like a Jag without some extended warranty behind it. I shudder to think what it might cost to repair some of the more arcane and flashy features in the car if it popped its clogs leaving you on the hard shoulder.
Wolfy
05-28-2024 08:06 AM
