Balancing alloy wheels
Delta, just because they are new tires doesn't mean that you can't have a bad tire. There is a process called "Road balancing". IT is a much more aggressive tire balancing method and it will bring out any flaw in a tire/rim. You can also have them mount up the tire in the balancer and then run a mic along the edge of the rim (as close to the rubber/metal interface). If you get any sort of wobble in the rim, that would indicate a bent rim.
Delta, if you only have a single tire that is the issue, then yes, rotating them front to back will help as a wobbly tire will not be felt as much if it is in the rear of the car. If this does help, then you can rotate one side of the car back to where it is now and see if the problem moves. From there, you can isolate the problem down to a single tire.
