The battery drain thread
Soooo I am sick and tired of battery drain problems on Jaguars. I have had a couple and the info Jaguar gives you is limited and a bit confusing. So I decided to start posting and writing all my research in one good article which I can update over time. It has the Jaguar specifications as well as my own research in good known cars. So if anybody has a battery drain problem can comment on what his solution was to help others.
Here is the link: jaghelp.com: Jaguar battery drain
Here I have the Jaguar technical specs on what the drain is supposed to be and as cars come to my shop (and stay over night) I'll do some battery drain tests and post the results. I already posed one for a 2001 XJ8.
aholbro1
08-05-2021 05:02 AM
