Brake module voltage
Hello everyone, I recently was working on a timing chain issue on another thread and while the car now runs I have some other bugs to sort out, I have a trac not available asc not available and abs light, I removed the module and resoldered the power pins however I'm unable to verify power at the wires routed to the electric motor.. is the voltage to be a constant 12volts? Or is it activated by the ecm when it is to function? I noticed the light return this morning and I really would like to sort this out.. thank you for reading my post I appreciate the help..
[QUOTE=motorcarman;2669179]What DTC(s) is/are logged in the ABS module?
C1095 is the common one for the pump motor usually addressed by re-soldering the pins.
Other faults that have nothing to do with the pump motor will flag different DTCs.
Without the specific code, you are
Hello motorcarman ,thank you, yes it is c1095. I did solder the pins however the light is back on and I can't get a voltage reading from the 2 prong connector below the large harness plug. I have no power . I did an ohm test on the motor and it is showing continuity. Do you know what the specifications are for the power leads to the motor at idle,or the key in the on position? Perhaps i need to check my solder connection again..thank you so much
sorry about that, it's a 2002 xj8 I was hoping to get voltage specifications at the brake module pins . I dont know if its constant power ,or just has power when activated.. I have no voltage at the pins with key on.. thanks again
Torsten Holdermann
04-05-2023 03:38 AM
djpxk8
09-19-2017 09:03 PM
