Car wont start? READ THIS FIRST
In order to better help you, you might tell what year and model your Jaguar is, as well as where you live, as your elevation as well as temperature can be a factor.
Hi 67E, my jag is the 96 4.0 Coupe, one of the first exemplars. I live in Switzerland at around 400m (1,300 ft). I found few threads describing problems similar to mine ( difficult start then runs fine), but they don’t have the heat factor involved. My Issue activates at around 25 degrees Celsius so we are not talking extreme temperatures either.
I have read your message fully and tried everything but nothing seems to work.
my husband was driving the car it made a noise then on the dash it said engine system fault it was still driving fir another 10mins till he reach his destination then turned it off and since then it will not start it turns over but will not start at first we thought it was the belt on the high pressure fuel pump but that is working we have fully charged battery we have cleaned the fuel pump it has half a tank of diesel fuel is getting to the fuel pump we have disconnected the battery for a reset but nothing is working help me please.
Welcome to the Forums.
When the beast is sorted please do an Intro in the New Members Area.
I suggest a re-ask of this in the XF (X250) Tech Section, down the home page a tad further.
Being a diesel, I have NO idea, but the members in there with Diesels will have answers.
Good luck.
GGG (05-29-2020)
You have already followed a logical course of troubleshooting and eliminated the most likely causes. The "engine system fault" warning will have been displayed because a relevant DTC (Diagnostic Trouble Code) has been set. To determine stored or pending codes requires Jaguar Diagnostics or a compatible code reader.
The following 2 users liked this post by GGG:
Grant Francis (05-29-2020),
Jack-Hammer (09-10-2021)
1964Daimler
09-02-2015 11:41 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
