CarMd, or any other auto diagnostic device
Received 3,905 Likes
Scotty, what I personally do is I have spent $70 on a basic code reader from the auto parts store. From there, you can read the engine codes and get what is causing the check engine light to flash. From there, you can either post the codes here or you can do a little bit of research yourself and see what you can find (information from other Ford products will be relative to your search). You can do most of this in just a few minutes.
Now, to make things a bit easier, you can find a copy of the JTIS CD, there is a section in it that you can look up the codes you are getting and it will list the most likely suspects. If you have multiple codes, then you normally narrow it down to a single component by looking at what parts they recommend replacing and see which ones are common to all of the codes.
Please note that I specifically talk about engine codes. If you are wanting something that can read the body codes, tranny codes, etc, then you are going to be dropping quite a pretty penny to be able to do that since you will be into the professional level readers. The higher end ones are nicer for the fact that they will give you a brief explaination of what the code is and the high, high end ones will give you real time data logging/viewing of the engine. If you do some looking around, there are some kits out there that you can take your laptop/higher end hand held devices and plug a cable into it that will plug into the car. Then, with their special program, you can get a lot of these same features (but not all and the options vary between each one and what device you are using). These can run normally around $200. So, that is another option.
Guest
Posts: n/a
Thumbs up from me!
Hey there,
I have tried this CarMD device before. I was visiting my cousin this hoilday and his wife bought him one for Christmas.
Since i had a Check engine light on my jag already and i already knew the cause... i wanted to test it out.
good packaging, device felt solid as well.
So i tried it out, plugged it in and got a code. Tested out their database, and gave me a report... it was right!
the most likely cause for my code with my particular make/model matched up to what i knew was wrong with my car.
from my experience this device works really well.
Marka
22
09-11-2016 12:09 AM
advertising, auto, automotive, carmd, codes, device, devices, diagnostic, forum, home, jaguar, location, obd2, readers, type
