Change Diff Ratio with IDS/SDD?
#41
Well I was able to look at the TCM files with a program called SwapFTL
The .phx files all appear to be identical;
http://dl.dropbox.com/u/11575086/z65...350row.phx.jpg
http://dl.dropbox.com/u/11575086/z65...103row.phx.jpg
http://dl.dropbox.com/u/11575086/z66...350fow.phx.jpg
The .dhx files don't have any tags or headers to identify them, and looking at the binary data it's impossible to see the difference by eye.
But i would guess that the .phx is the generic file from ZF for the 6HP26, and then the .dhx contains the specifics for the particular engine/diff combination.
Still not any closer to cracking this, but maybe someone will see something...
I'd be curious to look at the TCM files from the 4.2L X150, if they look the same when opened with the SwapFTL then maybe it might work....
This is the only chance I can see because the 4.2L X150 has a J-Gate, the XF also has a 3.31:1 but that's with the rotary gear selector...
Although the XK has a different part number for the Mechatronic than the X350, it's still worth a look....
#42
Are further update to this one.
So I tried renaming both the .phx & .dhx files from the X103, and loading them into the X350 XJR. The files loaded to the TCM, but I immediately got a Gearbox Fault on the dash, and the DTC P0610 which is "Incorrect Configuration or Calibration Loaded"
I reloaded the original .dhx file for the X350 XJR, & reflashed again (.phx from XKR, .dhx from XJR) and it was all back to normal. Then I tried the .dhx file from the 3.0L V6, with the .dhx from the XJR and it was the same.
So 100% that the .phx file is a generic one-size-fits-all for the ZF 6HP26 in our cars, and the .dhx file (which is unreadable as binary) holds the actual calibration info for model/engine/diff ratio.
I haven't bothered with trying the .dhx file from the 3.0L V6, because it will either bring up the P0610, or if it did work, the shift points will be all wrong.
So safe to say we are completely done with trying a diff ratio swap using SDD.
However....
In the meantime, I got in contact with a guy in Eastern Europe, who says he can reprogram the TCM for the Jaguar ZF 6HP26. He has a special rig that he can plug the TCM into and "read, copy, write and edit" all information in the TCM. He claims to have done Land Rovers before, which would be the same as Jaguar.
The only issues with this are that you need to physically remove the TCM from the transmission & send it to him for reprogramming each time.
I had a lot of back-n-forth by email with him, some of my questions weren't answered, but if he can do what he says it seems we might finally have an option to tune the TCM in the ZF cars.
Not sure if i'll go ahead with it right now, waiting to see if DTS can come up with a clutch LSD to suit the X350 / S-Type...
However....
Brutal (02-11-2013)
#43
Received 2,193 Likes
AND THIS BEGS THE STATEMENT OF, GET A TCM FROM A DONOR (SALVAGED) TRANS A SEND IT OFF. THEN IT BECOMES A CORE PROCESS. WE SEND A REFLASHED UNIT TO YOU, YOU SEND YOUR CORE BACK AND IT GOES TO THE NEXT BUYER AFTER FLASHED TO MINIMISE DOWN TIME.
AND 9 MONTHS AND COUNTING ON MY NISSAN ENGINE WITH THE KENNE BELL BUTS ITS ALMOST DONE I MADE MY OWN LOWER INTAKE/INTERCOOLER BOX FROM WOOD TO MOCK UP AND SURPISINGLY THE HOOD CLOSES, THE ORIGINAL BELT SETUP WILL WORK WITH A CUSTOM SC PULLEY. ITS BEEN AT THE FAB SHOP BEING MADE IN ALUMINUM AND HAD TO GET 1000CC INJECTORS TO SUPPORT FUEL NEEDS ILL GUESS ILL HAVE TO POST UP HERE WHEN DONE BUT HERE'S A LINK TO A THREAD ON IT WITH PICS
New Mod, Kenne Bell Twin Screw Super Charger - Second Generation Nissan Xterra Forums (2005+)
OOOPS SORRY ABOUT CAPS
#44
However....
However....
.dhx = data hex
educated guess ... but it matches the observed behaviour
#45
Coild be Plums, I searched high & low for an explanation, couldn't find any info anywhere...
Brutal, the info i got from ZF says that the TCM and the valve body are calibrated in the factory as one Mechatronic, swapping just the TCM is not advised as it has not been corrected for the reaction time of those specific solenoids.
Also the guy in Varna who says he can reprogram the TCM needs the original from the specific car, as he reads the info out, edits it, and then reloads it. I sent him the original .phx & .dhx files from SDD and he said he couldn't do anything with them...
Also no chance of reprogramming via the OBD port or connecting to the plug on the side of the tranny, the TCM has to come out unfortunately...
#46
hmm... I don't believe what ZF appear to have said. Any car of a certain MY and engine type gets the same phx/dhx so any variations are either stored once at manufacture or - far more likely - learned. That's what the "adaptions" are, I reckon.
Also, it's acceptable to replace parts and you don't have to send it back to have this mystical (pah, mythical) stuff tweaked.
It's ZF trying FUD so we don't mess.
#47
#48
This is the other company I wrote to. No response back for past 2 days.
Cambo, If you haven't already contacted them, let me know and I will call tomorrow.
Powertrain Control Solutions - Contact Us
TCM-2600
http://www.powertraincontrolsolution...oduct=TCM-2600
TCM-2600
#49
#51
There is a picture of the stripped TCM on page 15 of this document http://www.sonnax.com/system/pdfs/37...AutoChoice.pdf
I don't have a spare TCM good or bad, simply haven't been able to find one cheap...
#52
I wonder what would be the easiest way to chase down a bad TCM module.
Perhaps someone following this thread works in a trans shop and has one that can be torn apart.
#53
We'll see how fast he gets back to me with confirmation that their control unit will do what we need.
Joe
Cambo (02-15-2013)
#54
I'm about to embark on a 3 week business trip, and when i get back the XJR is going in to my mechanic for a full 100'000mi service, 3lb pulley, bigger intercooler pump (Bosch), and if all goes well, new oil/filter for the trans, 3.58 gears and a Quaife LSD.
I've already ordered the 3.58 LS gears from the US, just waiting on a shipping confirmation before I order the Quaife from TL Jaguar.
The issue now is which way to go for the TCM reprogram?
Softelectronic hasn't got back to me with a firm price for the reprogramming yet, and i am very open to a piggyback TCM2600 from PTCS, so both options are on the table right now.
I am running out of time to make a decision. The car needs to be up & running by the end of March for the Nürburgring trip. So Joe, please please please keep on top of these guys, i'm ready to order now.
I'm not going to put in the Quaife unless I can do the gear swap at the same time...
#55
It would be good to know how many Jaguar owners would like to be able to change gear ratios and trans shift points. The larger the market, I am sure the better the support will be. I've also read that there are many BMW owners in a similar situation as us.
I would like to get my hands on a bad TCM for the 6hp26 trans. I am pretty sure that the TCM is made by Bosch. The ZF TCM just has to have a common processor and CAN tranlator in it. It can't be much different than any other CAN module.
#56
Any idea what the TCM2600 retails for approx?
I don't want to change diff ratio's in my STR; I just want to address the short shift in the early gears,
Does your XJR short shift gears 1-3 as the STR does?
Does the XKR shift to redline in the first 3 gears, or is that a misconception?
If the TCM configuration, including shift points, is in the phx/dhx files, then why does flashing the TCM with the XKR files not work?
Who is the contact in europe that claims to read/write the TCM module?
How difficult is it to remove the TCM from the transmission, do you happen to know?
thanks cambo for doin all this legwork,
#57
Couldn't find the TCM2600 on any of thier resellers websites, but based on the other TCM's they offer, I would guess something less than $1000, but the easiest answer for that is to ask PTCS...
the issue of short-shifting has me confused after so many posts/threads, what rpm does the STR shift at for 1-2?
The shift 1-2 in sport mode is at ~5900rpm in my 2005 XJR.
steveinfrance informed us that his 4.2L XKR also shifts 1-2 at ~5900rpm
OK so the .phx file is a generic "ZF" file for the transmission, which suits all the Jags with the 1st Gen 6HP26, it doesn't have any model specific calibration data in it. The .dhx is the model specific file. I tried flashing the XKR .dhx file into the XJR and it brought up the Gearbox Fault and the DTC for wrong calibration. The .phx being a generic file can be renamed & loaded into any car.
The .dhx obviously also has some model-specific identifiers in it, the TCM knew it was in an XJR but loaded with an XKR file, hence the error message. If someone can identify the name of the .dhx file for the STR, I could compare it to the others as per the post at the top of this page.
It was mentioned that the later model STR's did not "short shift" so there might be a chance of loading that file into the earlier models??? I don't have an STR to play with here, so 'fraid I can't help much with that.
Ah, more bad news... The company is Softelectronic in Varna, Bulgaria. But they informed me by email today that they cannot reprogram the TCM for a diff ratio swap. I had previously asked them about a ratio swap and raising the shift points, to which they said "yes we can do everything" but when I pinned them down i.e. "please confirm that you can reprogram the TCM for a different axle ratio" they came back with a "no, sorry" so I guess we can forget these guys too...bummer because I already paid for the 3.58 gears...
You have to drain all the fluid from the trans. Drop the oil pan. Unbolt the Mechatronic (valve block) and then remove the TCM from the Mechatronic. So basically to remove the TCM you are looking at an expensive fluid change....
You're welcome, but we haven't actually acheived anything yet....
Sooo....where does that leave us for now?
Well, it's up to PTCS and their TCM2600...fingers crossed....
I've got a set of brand new 3.58:1 gears on the way that can't be used...
And a car with no LSD...and i cannot justify putting in the LSD now, just to pull the whole thing apart again to change the gears. AND i've got the oil/filter kit for the trans waiting...but no point in opening up the trans twice if you see where i'm coming from....
#59
#60
