Change Diff Ratio with IDS/SDD?
Old 06-22-2016, 05:21 PM
Cambo's Avatar
Received 4,461 Likes on 2,427 Posts
OK here's the latest.
There are four different software platforms depending on which model year of vehicle, and the solution to changing ratio's is different for each one.
X308/X100 AJ26 engine - needs a custom-written PCM program
X308/X100 AJ27 engine - needs a custom-written PCM program, but it's different to AJ26
X350/X202/X103 (up to 2005MY) - needs a modification to the VID block
X356/X206/X150/X250 (2006MY onward) - needs a modification to the CCF
The AJ26 is still a work in progress
The AJ27 is tested
The X350/X202/X103 is tested (VID)
The X356/X206/X150/X250 is also tested (CCF)
The 2006MY onward cars are the easiest to change.
In all cases an IDS/SDD is needed to make the changes.
I've had to put the ratio-swap in my car on the backburner because of other projects and my day-job. I'll get around to it sooner or later.
The following 3 users liked this post by Cambo:
GT42R (06-23-2016), oilstain (06-22-2016), Panthro (07-04-2016)
  #82
Old 06-22-2016, 06:15 PM
oilstain's Avatar
Thanks!
Interestingly, I've never seen the X356 designation anywhere else but on this subject. Makes sense, just didn't know about it.
  #83
Old 06-23-2016, 01:18 AM
JagV8's Avatar
Received 4,539 Likes on 3,948 Posts
My notes show X356 is XJ 2006-7, uses VID. IDS/SDD has/had/uses/used X356VIDBlock.xml
There are some XJ MY VINs in the Vehicle Spec file but I'm not sure exactly which range.
Cambo can probably post more.
  #84
Old 06-23-2016, 07:35 AM
Cambo's Avatar
Post more what?
If you hook up an X356 (an X350 from VIN G49701 to H18679) or an X358 (from VIN H18680 to H32732) to SDD it presents you with a CCF...
  #85
Old 06-23-2016, 11:17 AM
JagV8's Avatar
That'll probably do - I couldn't find the VIN range quickly.
  #86
Old 06-23-2016, 03:53 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
The AJ27 is tested
So writing to the VID failed?
  #87
Old 07-04-2016, 06:19 PM
Panthro's Avatar
Excellent news!
  #88
Old 07-05-2016, 02:09 PM
adam699's Avatar
So no luck on the AJ26 yet? I'm finally bought a VCM Rotunda of my own. (waiting on the shipment)
  #89
Old 07-06-2016, 07:50 PM
Received 1,425 Likes on 1,067 Posts
Now you need to find a legit version of IDS or SDD software.
FrickenJag
09-25-2016 08:00 PM
Gerard Radimaker
09-13-2015 10:33 AM
AtholC
09-09-2015 09:07 PM
hafren
09-07-2015 10:30 AM
1100me
09-07-2015 06:26 AM
Quick Reply: Change Diff Ratio with IDS/SDD?
