Change Diff Ratio with IDS/SDD?
#81
OK here's the latest.
There are four different software platforms depending on which model year of vehicle, and the solution to changing ratio's is different for each one.
X308/X100 AJ26 engine - needs a custom-written PCM program
X308/X100 AJ27 engine - needs a custom-written PCM program, but it's different to AJ26
X350/X202/X103 (up to 2005MY) - needs a modification to the VID block
X356/X206/X150/X250 (2006MY onward) - needs a modification to the CCF
The AJ26 is still a work in progress
The AJ27 is tested
The X350/X202/X103 is tested (VID)
The X356/X206/X150/X250 is also tested (CCF)
The 2006MY onward cars are the easiest to change.
In all cases an IDS/SDD is needed to make the changes.
I've had to put the ratio-swap in my car on the backburner because of other projects and my day-job. I'll get around to it sooner or later.
The AJ27 is tested
#83
Panthro (07-04-2016)
#84
#85
#86
#87
#89
Gerard Radimaker
09-13-2015 10:33 AM
hafren
09-07-2015 10:30 AM
