Christo's JTIS Download Site
#229
Hello; I'm new here, but would love to get the information for my 2004 S-Type 3.0. I see that only through 2003 is listed as to coverage, but hoping that some information is applicable to my '04; specifically steering column information regarding the spiral cassette replacement.
Great service you are providing; thanks 1,000,000!
JD
JD
#233
So...now what do I do?
I have two files...J-CD1 and JCD-2. When I extract them using WinZip, they go into a folder named desktop\jaguar\jtis.. There are some files that are *.dpp and *.exe files as well as the folders and files that are graphic. When I tried to run "setup.exe", nothing seemed to happen.
What have I done wrong?
Eric
Eric
#234
pm sent to ns boxing...
Toller something went wrong. When you extract j-cd1 it should make a fodler called j-cd1. In there should be 2 directorys and the setup. Try going here dao35\disk1\setup.exe - run that first and then try the main setup - let me know how you make out!
#235
Hi
When I try to run it that way it says my version of windows is not compatable, I am running vista . when I try o run the normal set-up it says its missing a directory path.
Any ideas.
Craig
Any ideas.
Craig
#236
I run it on a Vista machine 32bit. Do you know what version you have? Right click on my computer and left click on properties - read the screen if you don't know.
#239
Hmm, that could be the problem! I have never tried it on that version and wouldn't doubt that it would fail. Try to right click on the executables (setup.exe), go to properties and check the tabs for something that says run in compatibility mode. Choose an earlier version and see how you make out. Worst case do you have another computer maybe at a friends house or work?
