Christo's JTIS Download Site
#264
Thanks for the JTIS, had some difficulty opening them. Downloaded Jcd1 and jcd2, then tried to open with unzip program i already had, didn't work. Downloaded urs, still didn't work. Uninstalled my zip program, had to delete the two jcd's. Then first downloaded your unzip program, then both Jcd's, and it worked just fine. Thanks a million brother, jim.
#268
Pm's sent!
@ Trucknetjack it will run on Vista but not sure about the 64 bit version. I believe there was someone here that ran into this problem. If you have some issues, post here. Better yet if you go back a few pages in this thread there may be some info - either way let me know how you make out.
Christo
Christo
#272
Dear Christo, I'M the proud owner of a 2000 XJ-8 Vanden Plas no issues since new would love to have manual currently I am having power to the fuel pump Issues. Need Wiring Schematic for the fuel system.
#273
Christo, I downloaded the file and there are like 100 files in the folder that downloaded. I can't find one that will open though.
#274
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Open the forlder with the extracted files, in there you should find a setup file, double click that and just accept the defaults. If that installation should fail, go into the dao35/disk1 and run that setup 1st. (Only do this if the previous setup will not run. Let me know how you make out!
#275
christo,
I believe I read that your service manual download for the S-Type covers through the 2002 model year.
I have a 2005 S-Type 3.0. Any chance of me being able to download that particular service manual from your site at some point in the near future?
You provide a great service to the members here. Thanks for doing so....
#277
Guest
Posts: n/a
Hi I hope someone can help, I am converting a 1999 S-type 3.0l V6 to LPG and need to find out which wires on the injectors are the switched ones i.e the ones that get there trigger from the ecu, if anyone knows or has a wiring diagram of the injectors to ECU that would be really helpfull, or could you please give me the link to the JTIS
Thanks Paul
Thanks Paul
#280
Unzip it into another folder.
Open new folder and look for setup and double click.
accept all defaults.
If you get any errors during the setup go into the dao35/disk1 and run that setup first - then try the steps above.
The Vista 64 bit may give some trouble but we can cross that bridge when we get to it.
Christo
Christo
