Christo's JTIS Download Site
#282
Did you get any errors while extracting the files to the new location? If so you may need delete all copy's from your computer and re-download. If the extraction was clean and this happened on the setup, try running the setup out of the other directory I mentioned. I'll pm you my number so we chat - I'm home today!
#290
Guest
Posts: n/a
This is terrific! At first, I thought I was SOL as my exact year was not covered. I had forgotten that 95-97 XJR's are pretty much identical. After hunting around, I found the 95 xj series section deals with everything I need! Many thanks!
You've made my day!
You've made my day!
#296
JTIS on Windows 7
Anyone has any luck installing this on a Windows7 system?
I tried a few ways (XP, XP SP2 compatibility mode) and has been no luck. The DAO35 does not install and I think Windows 7 has that installed already.
#300
I believe my profile is now OK. So once again I am looking for workshop manuals / links for 1997 XK8 Convertible. Thanks again Terry
