Christo's JTIS Download Site
#144
Guest
Posts: n/a
Hi Christo I am a new member I have two jags....2002 Xkr and a 2003 S-type R .....I have a question I bought the cd workshop manual for Jaguar (JTIS) and it stops while installing says NTVDM.exe has stopped working, I have windows vista do you know what that is? By the way do you know of a free download site for my XK? thanks, Dino
#145
I believe it has something to with the program being a 16 bit application and your windows software if either 32 or 64 bit? Another user had the same issue with the package I am hosting.
There was a way to run the setup in a compatiblity mode where you right click the installation file and tell it to run in a 16 bit compatable mode. This has worked for some...
But another we had to do this as well...
We first made sure the program was uninstalled.
Ran windows updates to make sure Vista was current.
In the software that I am hosting there is a DAO directory, there might be one on your cd if you explore it. In the DAO we ran a setup file in there and then began the installation and all went well.
#146
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
oh bugger im running vista 64bit and it loads but crashes every time and the setup in the doa refuses to run
bugger bugger bugger
but thanks for letting me have the chance to try
cheers
cheers
#148
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Look for the setup file, should have an icon that is a picture of a computer.
Right click on that and left click on properties,
Click on the compatability tab,
Check the box next to "run this program in compatability mode for"
I would start out by choosing XP, if that doesnt work for you try the next until you can get thru the installation - you should be fine...
Let me know how you make out. You made need to do this for the DAO too, not sure...
#149
No more buggers I think we can get past this...![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
not to worry gonna whack it on the missus lappy, she wont have a clue what it is
cheers for trying
