Cleaning charge coolers
Old 05-12-2020 | 11:42 AM
James Hunt's Avatar
Default Cleaning charge coolers
Whilst my car is in bits I am cleaning as many things as I can. I have removed the two charge coolers (as photo below). What is the best way to clean these?
Old 05-12-2020 | 01:42 PM
jazzyjags's Avatar
I soaked mine in degreaser for 2 days and rinsed them a few times. I also sprayed a good foaming engine cleaner inside of each manifold port to clean the heat exchanger. You cant really get to scrub it inside, but if you run pressurized water (just from the "jet" setting on your typical garden hose nozzle) it makes a difference when rinsing.
Old 05-12-2020 | 01:43 PM
jazzyjags's Avatar
Make sure you remove that sensor first!
Old 05-13-2020 | 05:07 AM
James Hunt's Avatar
Thanks. I'll give that a go
petemohr
05-25-2019 04:05 AM
Dukejag
03-26-2019 02:58 PM
brinny
04-23-2018 06:14 PM
XJ8JR
09-29-2014 08:51 PM
Quick Reply: Cleaning charge coolers
