Cloned dealer scan tool
#142
Hi Cambo351
Re your faulty mongoose. Just to let you know I bought a JLR VCM from uobd2 and I could never get the thing to work so after much discussion with them, I took a leap of faith and sent it back after I'd had it for 9 months asking for a refund. They didn't give me a refund but did send me a brand new replacement which works fine. So hopefully you'll get similar treatment. Good luck.
#143
Was bound to happen. Actually the conspiracy-theorist in me thinks that maybe this thread (and a similar one on the UK site) might have contributed to the SDD getting locked down. Never before had there been such discussion on an open forum about IDS/SDD. There was one forum in the UK, kind of underground, which was blatantly talking about hacked versions and trading user credentials, but it's been shut down since end of August or so.....
I followed the site that was shut down. Posting copyright software for free download may have contributed to its demise.
While it seems unfair for JLR and other manufacturers to restrict access to diagnostics software, there are some legitimate reasons to do so. Vehicle theft and emissions tampering are two reasons that come to mind.
Then, there are us folks who want to help an aging vehicle live to become a classic, want/need affordable ownership or are compulsive do-it-yourselfers. (I'm all three.)
Thanks, Drew Tech, for dealing direct. Thanks to shops reselling their old software. And thanks to forum members, especially techs, for sharing what you know.
Best regards,
Bill
The following 2 users liked this post by Bill400:
jimlombardi (10-14-2012),
xjrguy (10-10-2012)
#144
I got my mongooser and as expected, the software included with it was corrupt. So I downloaded the current version of v131 off of the Jaguar diagnostic delivery website and installed it instead. After some very thorough searching online, (and buying an invitation) I was able to authenticate the v131 off line. That is, no need to connect to the internet.
I think it is all working, I have only played with it for about an hour, so I do not know if the full capabilities of the mongooser and the v131 software are available to me.
Note: I cannot answer questions of how to get the software working or why it doesn't it do this, or how can I do that, because I don't know myself. I will have to research and read and search and try things out, to see what happens. This is the learning process, I suggest you try it too.
#145
#146
...also used the new combo to not only automatically lower the passenger mirror when in REVERSE, but also the driver's mirror! You can also enable/disable the audible chirp for the alarm too in the SDD...oh yah, plus you can enable/disable the passive arming of the security system (which I didn't do, I like to leave the key in the car as it rests in the garage). I haven't found the 'global close' option just yet, but I'm sure I will somwhere along the line if its in there. I'd like to have that turned on. I just have to remember to return it back to normal if I ever resell it.
#148
I got the USB elm327 to go VERY fast via (high speed) CAN, dumping all CAN bus data (via a fast USB port), so I don't think its micro type is relevant. The usual cause of slowness is that the software connecting to the elm is using ISO (which is really slow). Worse, a lot of the software uses the elm commands with various optional padding still enabled so loses yet more bandwidth.
#149
Is there some sticky or dedicated post for "guidelines for using SDD", or "how to use IDS"? I would think that now more people are being exposed to the software, some sort of guide would help us newbies from making bad mistakes. I am not suggesting one person write up a user's manual, but if anyone wants to share their problem solving experience or tips, I think it would be help full.
Or is there already a forum or topic such as this?
#150
#151
#152
#153
If you have a dual core processor, you can use WinXP SP3. But you still need IE6.
If you have enough horsepower to handle Win7, stick with SP1 or earlier for now; and you'll need Internet Explorer 8. Only Win7 32-bit is supported, not 64-bit.
If any Java update is needed, it will tell you when an update is ready.
Hope that helps!
#154
Some digital documents for the SDD software were generously offered to me... I haven't opened any of them yet, but at over 41MB in the zip file, there's sure to be some good information in there. Let me get the files cataloged and uploaded to the mediafire hosting site, then I'll get some links into this thread for starters. Give me a few days, I've got a crazy week at the office planned.
Cambo (10-15-2012)
#155
That will be very much appreciated!
#156
I am running XP Pro SP3, but not IE6. What's the newest version that'll run on XP, IE8? That'll be it. Everything seems to work OK, the only thing is that SDD takes over IE and you lose the tabbed browsing. Also noticed that it's messed with Windows Explorer i've lost the forward, back & up buttons.
#157
#158
IE 8......same thing. Company IT people took it upon themselves to update machines to IE 8 without consulting us. Problems ensued. I had to remove IE 8 and reinstall IE 6 on all machines that had SDD. They have been fine since.
As far as SDD taking over Internet Explorer......get used to it on these machines, can't get away from it. I just install Firefox to use for any browsing I need to do other than TOPIx.
Word of caution, DO NOT install Google Chrome on any SDD machine. Chrome takes over some settings even worse than SDD does with IE. Everything from Google has tentacles, I hate it.
Vista?? Kick it to the curb if you want to do diagnostics, period.
Cheers,
JagV8 (10-16-2012)
#159
+1 I found this out the hardway, its now banned at our office (cause I always had to fix what google chrome screwed up!) and I warned my family that I won't be fixing any more chrome-installed machines anymore. We'll see if the short memory returns.
xjrguy (10-15-2012)
#160
