Cloned dealer scan tool
#162
#164
Thanks to our mysterious literature 'benefactor', there is some good information included in these files. I've got lots of reading time planned for that Manual.
SDD
- IDS-SDD-JLR Manual (February 2012)
- IDS Maintenance & Troubleshooting Guide v2.2
- IDS to SDD Transistion Guide v2.5 (sorry Bob, no "WDS to SDD Transition support
- SDD New Features
- SDD Newsletters (includes hints and tips)
IDS
- IDS Introduction for New Users
- IDS Maintenance Guide v1.3
- IDS Training (this is the biggee)
- IDS Guide Release
Last edited by H20boy; 10-18-2012 at 02:56 PM. Reason: added IDS specific manual and documents
#165
I should add a note on the subject of Java, 'cause I just had an incident.
If a flag comes up about a Java Update being available, you should heed that notification and get the update. When Java detects an update, it seems to be in some sort of limbo and SDD usually has issues. I have learned that over time. Likewise, if I'm in the middle of something with SDD when the Java flag comes up, I shut down SDD like I'm done, and get the update. Then I go back into SDD and proceed with whatever I was doing.
I've just learned to make sure Java is happy before I do anything with SDD. It relies heavily on Java.
Cheers,
Cheers,
#166
Are you sure the legacy software also works in Win 7 32bit?
#168
#169
I guess the next question we have to answer is whether you have a clone Mongoose or the real deal. Both of mine are the real items, almost $600 apiece.
Cheers,
#170
Although its a clone mongoose (I have tried it with a VCM as well), I don't think it is related to the h/w tool, as all is working fine in my winXP sp3 vm (virtual machine), so both the mongoose as the vcm with tabman.
If you think it should work, I can setup a new Win7 32b vm again, and will give it another try.
#171
Well, I really do think it should work. I just don't use the Win7 setup often enough to say mine does for sure. My XP machine works very well with IDS and the Mongoose.
I hate to see you go to the trouble of loading up another drive; but on the other hand, if the clone device is part of the problem, I guess that would be good to know.
Good luck!
Good luck!
#172
#173
#174
Of course, everything works with a VCM, with the MongoosePro JLR for instance, diagnostics, code reading and datalogging work, but you can't flash program modules on the older cars. I think I said earlier, that's why DrewTech indicates it doesn't 'support' the first generation S-Type. It won't flash, but it works for most other things.
Oh, PM on the way shortly.
Cheers,
wesmc2 (10-19-2012)
#176
#177
I gotta say thanks to all you guys for all of this info BUT I am a german car tech and all of the variables are confusing the heck outta me :-)
I have Jags from '89(xjs), 99(xj8), 03(XKR), and 09(supercharged xf). What I need to do is diag and re-flash/updates. I do not mind spending 500-800. I have seen used rotunda's, knock-off new metal rotunda's, mongoose, and mongoose knock-offs. Can anyone give me a recomendation? I have a few laptops of variable vintage that can be used for this.
The software/licensing/ect is total alphabet soup. Is there a quick and easy answer for somebody ready to spend under a grand usd?
My plan was to order from mongoose. My understanding is that I will have diag on all 99 and up cars but no flash abilities. Is this correct?
#178
btw- I will start reading all the info in the waterboy's links as soon as I get home on monday, but I would really like to order the tool now and have the stuff here to work with while I was going through the links. And I need to fix my darn car asap, daily driving my tow vehicle is eating me alive.
#179
As far as flash programming.......I had some comments on that a while back. Reflashing just isn't the first thing you should consider. Here's the post:
https://www.jaguarforums.com/forum/s...67/#post598451
Cheers,
wesmc2 (10-19-2012)
