Custom PIDs for Torque App - oil temp, oil level, trans temp, and more
Old 02-01-2019, 12:59 AM
Cambo's Avatar
Received 4,464 Likes on 2,427 Posts
Default Custom PIDs for Torque App - oil temp, oil level, trans temp, and more
If you have a 2010-onward Jag or Land Rover with the electronic oil level sensor, and are using Torque Pro App on Android, one of the members of our group has reverse engineered some useful PIDs so you can now see measurements on Torque of Engine Oil Level, Engine Oil Temperature, Transmission Fluid Temperature, E-Diff Fluid Temperature, and more.
Attached PDF file outlines the process for adding the custom PIDs to Torque Pro, you will need to download a .csv file, there is a link in the document to download the file.
This information/instruction is provided for free! Hope some people might find it helpful.
The following 18 users liked this post by Cambo:
CleverName (02-02-2019), Don B (08-11-2024), f-driver (02-01-2019), GGG (02-01-2019), guy (02-07-2020), hafren (02-02-2019), jaguny (02-25-2019), JgaXkr (02-01-2019), mcphill (09-28-2022), MRomanik (02-01-2019), Norri (02-04-2019), Queen and Country (05-09-2019), ralphwg (02-02-2019), Reaxions (02-18-2023), Reverend Sam (02-08-2020), sklimii (02-01-2019), tberg (02-02-2019), u102768 (02-01-2019) and 13 others liked this post. (Show less...)
Old 02-01-2019, 02:21 AM
GGG is offline
Received 16,867 Likes on 12,186 Posts
Cameron,
An excellent idea. I was intrigued when I read your mention of this on F-Type forum earlier in the week. Downloaded and will give it a go this weekend.
Old 02-02-2019, 11:50 AM
Cee Jay's Avatar
Received 5,511 Likes on 3,242 Posts
Is the .cvs file just a formatted Excel spreadsheet that adds data to the App? I sort of expected something else.
Old 02-02-2019, 05:33 PM
CleverName's Avatar
^ I hope so. I did a copy and paste to excel as Dropbox will not function without me allowing 3rd party cookies.
Old 02-02-2019, 06:50 PM
Sean W's Avatar
Received 4,267 Likes on 2,384 Posts
Cee Jay (02-05-2019)
Old 02-02-2019, 08:41 PM
AlexJag's Avatar
Sponsor
Nice work Cambo! Anything available for the 4.2?
Old 02-04-2019, 07:18 AM
clubairth1's Avatar
Received 2,457 Likes on 1,931 Posts
Thanks much Cambo!
Any chance we can get a inch/psi version?
Old 02-04-2019, 08:37 AM
GGG is offline
Works perfectly:
Any chance of actual tyre pressures from the TPMS with a future version ..........?
Cambo (02-06-2019)
Old 02-06-2019, 07:47 PM
Cambo's Avatar
Thanks much Cambo!
Here it is in imperial https://www.dropbox.com/s/wjzlwuzvx1...erial.csv?dl=0 hopefully this will work for you non-metric heathens
Originally Posted by GGG
Works perfectly:
Sadly no, the way the TPMS module sends data in an X150 is not on HS-CAN, and even then it only broadcasts when a fault (bad sensor, deflation, etc) is present, so no live data.
GGG (02-07-2019)
Old 02-06-2019, 08:53 PM
CleverName's Avatar
Thanks Cambo......
(And yes I hate being one of those non-metric heathens....sigh....)
Old 02-07-2019, 02:54 AM
GGG is offline
I buy my fuel in litres but check consumption in MPG. On holiday I check the weather forecast in deg F but engine temperature in deg C. Tyre pressures have to be in PSI but torque only means anything to me in nM. This must make me a semi-metric imperialist.
guy (02-07-2020)
Old 02-07-2019, 03:25 AM
JagV8's Avatar
Received 4,551 Likes on 3,958 Posts
Can the sensors be read using some sort of (wireless?) box? I suppose they must be wireless of some kind... but what kind? How's the car reading them?
Old 02-07-2019, 05:26 AM
Cambo's Avatar
In the X150 and X250 there is a separate TPMS module, which is wired up to the 4x initiators, and a single RF receiver that receives the signals from the 4x sensors.
It's basically a closed-loop standalone system which only broadcasts fault messages on MS-CAN to the instrument cluster, you don't hear from it unless something is wrong.
Other vehicles, like the F-Type, Discovery 4, Range Rovers, etc have the TPMS incorporated into the Body Control Module, and you could get live data from them, but not in the dumb system in the X150/X250.
Old 02-07-2019, 05:47 AM
GGG is offline
As I haven't had a TPMS warning on my XK, I've just tested to see how and when it triggers.
Front recommended tyre pressure is 33 psi. Gradually deflating the tyre triggered the warning at 26 psi. The TPMS on the XK genuinely is "dumb". I can tell by looking at a tyre it is seriously under-inflated long before it approaches 20% below recommended pressure.
Presumably the warning trigger point is manufacturer determined, hard coded and not mandated?
Old 02-07-2019, 05:56 AM
Cambo's Avatar
Safe to say they spent the least amount of money possible to fulfill whatever the US/EU legislation was requiring.
Old 02-07-2019, 06:34 AM
JagV8's Avatar
Thanks - but I was hoping as a work-around there might be a standalone box known to work that a car owner could buy from some suitable site.
Old 02-10-2019, 08:32 AM
clubairth1's Avatar
Thanks again Cambo!!
Your a fountain of Jaguar information!
Any chance this can be added to the sticky's?
Shame to have to search for something so useful.
Old 02-25-2019, 01:09 PM
Queen and Country's Avatar
Received 2,384 Likes on 1,609 Posts
Is that correct, 5.5 liters of oil?
Old 02-25-2019, 05:10 PM
GGG is offline
The car was sitting on the ramp into my garage for the photo. Amazing the difference even a slight incline can make to the reading.
Queen and Country (02-25-2019)
Old 05-09-2019, 02:40 PM
Tel's Avatar
Tel
Tel is offline
Excellent app, thanks for all the efforts to gain the pids for the extra info...
Question regrading the IAT2 reading - Mine is reading 60 deg C on initial startup, rising to 85C after a 5 minute idle!!!
Checked that the .CSV file was intact and all appears correct - Am I not ticking a box somewhere in the app or is the scaling gone to rats?
Quick Reply: Custom PIDs for Torque App - oil temp, oil level, trans temp, and more
