Diagnostics Tool Help
Looking for a little guidance on a diagnostics tool setup. From my research on here I have determined that the best setup for my vehicle is as follows
VCM or Mongoose and IDS V130
From what I can tell both the VCM and Mongoose are discontinued. Can someone please confirm this assertion?
If not can someone recommend a supplier?
I am also looking for some guidance on where to find the files needed for IDS v130
Received 3,892 Likes
UnoJag, it does appear that the main line of cables is gone, but there are a few knock offs that may be worth a try. Here is one I found on ebay.
For Land Rover/Jaguar JLR SDD PRO V160 Cable Car USB OBD-2 Scanner Code Reader | eBay
As for the files, hopefully a member around here can help you out. I know the cable comes with V163 which would work on your car. The question then becomes what you need to do to ensure Version 163 works like you need. I find that is the harder thing to deal with and overcome.
Darrol2004
07-10-2023 05:53 AM
