Driver door not locking 2009 XF
I have had this problem on my 2004 xj v8 and traced it to the microswitch in the actuator.I don't know if the same switch is used in the XF but I was unable to obtain the switch itself.
You can buy a new actuator (expensive), an used actuator ( even cheaper) or I found that some used ford actuators (really cheap) have the same microswitch which you can cut out and solder into your actuator.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
