ECU prog failed
Hello,
On Jaguar X Type 2009 2.2d Executive BVA DPF
Having a engine warning light and sometimes gearbox fault message 2 months, I flashed the TCM with mongoose clone, i ve been going for a ride to test if gearbox fault would appear but it was all good ( in Sport mode also)
I still had some strange feeling : like speed would downgrade with delay, power was missing past 3000rpm
Then i wanted to reprogram the generic module ...
it asked to remove ABS fuse then stability module fuse, what i did , then module programming failed midway
On my dashboard, i see consumption ( in french) module error , ABS warning light, stability fault, now car wont start
I messed up cause battery voltage was 12.5 in ignition II, engine off ( and maybe other factor like mongoose clone, no VCM ...)
I charged battery all night , now its at 13.5v ignition off but when i go in ignition II , then engine cooler goes max speed and i still have 12.5v
Im using a chinese power supply of 50A,i will try to see if i can turn off engine cooler but maybe i have power drain somewhere... Edit : i removed cooler fuse f16 et now i have 13.2v with engine off
I performed an ECU reset, by touching - and + but problem is still same
I knew i had some electronic mess, i wanted to bring it to a tech this week ... but now car dont even start
I tried to reconfigure ABS module but i have problem of communication now ...
Is there a way to make ECU return to where it was ?
Edit: i tried to do rectification procedure with connecting -/+ at the rectification screen but now luck
Thanks for any help anyone would bring me![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Anton
Anton
Welcome to the forum Anton,
Mongoose clones and "cracked" versions of SDD are notoriously unreliable for programming. Some members have been lucky but others have had to take their "bricked" vehicle to the dealer.
I would normally move a question from General Tech Help to the relevant model forum but I will leave your post here as it is likely to be seen by more members with module programming experience.
When you have time, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Hello,
I'm using SDD V131.03 , with have SPA and VBF, all given from ebay download.
I installed SPA 131V2, but in SDD , its saying it requires SPA V131V2 ...
i wonder if it installed at the correct location, the path is the following : "Program Files\JLR\IDS\SPA\JLRE5\WORKING" then in this folder there are ton of other folders, does it sound familiar to anyone ?
An other problem is i cant read TSB inside SDD , when i click on "read", it wants to open "doc.ressource.action" something
Much thanks
Much thanks
Do you have the correct Drew Tech "Mongoose" or the unknown Chinese clone called the "Mangoose".
As was posted above the recommendation is to use the Mangoose clone ONLY for reading the vehicle to get and clear codes.
DO NOT EVER try to program any modules with it! I have seen pictures of a Land Rover with dozens of modules blown up this way and a bill in the $10,000+ range!!
There is a lot of details to using the SDD. Is your computer attached to the internet? You should not be and do not try any on-line updates to SDD either.
Hope you have not damaged anything and will you post back on the repair?
jczaban (04-04-2019)
I'm using mongoose pro clone ... Sdd 131.03 with calibration file spa and vbf, set at 08/2012 without any connection to internet
I have a problem with can bus ..
Along with abs dsc module
Im not sure if its really a can bus problem, it seems a whole part got messed up, like i cannot close all door at same time...
I will look first into that before bringing to a tech, also i have 2009 model and there is less litterature about it
Is there an offordable way to program module ? Some vcm ii are like 140 euros but i dunno if its the real deal..
Thx
Thx
i had a similar problem when I did a reflash of the tcm....i lost communication from the pcm to tcm while it was flashing...i was left with a vehicle that would start but no movement, and a bunch of trans codes...i also have the same sdd 131.03 from ebay....I had a couple times where it acted funny prior to my trans issue...what I ended up doing was uninstalling sdd altogether...even the calibration and spa files...I reinstalled the 131 full only with the cal and spa files...i was able to configure the tcm as a new module and everything went great....you have to get to the screen where sdd has module configuration...usually by going through the diagnosis tab and further to the powertrain tab...sometimes you will see the configure on the recommendation tab or on the extras tab..the extras tab does not pop up automatically most of the time....you have to run something on the recommendations first usually..I left off the updates because I felt there was a glitch in one of them...since the reinstall I have had zero problems...the main thing is to establish comm with the pcm and go from there....worth a try.....also when you have your vci cable plugged in does it read as a clone or a genuine mongoose...hope this gives you some direction...I am still learning sdd myself, but i am comfortable with this advice
Its read as mongoose pro, i used the mongoose pro driver also
I will try to install sdd again yeah its a good idea
Pcm was in extra tab, i mainly enter 3 symptoms abs light, dsc message, and car wont start
It gives some module conf/new and first of all can bus problem
Before messing up, i had some can bus dtc in the trip/hold, people says its not relevant cause its old code, so maybe its some old code poping up, but then i have communication fault when trying to configure any module
I also tried to do "rectification procedure" like one member said, but i think i messed up, i made a reset bringing the - to the + but the i separated the + from the battery, i need to try rectification again
Thx for inputs
Thx for inputs
Thx for inputs
Thx for inputs
Yeah its always green ... only battery was yellow because cooler running full speed and was making drop my voltage from 13.2 to 12.6 V
yes i checked first "network trouble"box, i think it gives me some pinpoint test $ECM $EDCM but i cannot "READ" anything, might be corrected by reinstall
and for the sessions, i have to go through them all, and find a way to deduce on which one has been performed the PCM programmation, cause they are all with unrelevant date ( i set manually the date to aug 2018)
Thx
Thx
You should be good with your vci cable...in the diagnosis tab have you tried to select communication....it should be the first one on top, and see what options you have there...also you can reopen a session before you lost communication if you have it...try the reinstall ...just 131...no updates, and give it a go
50 amps might be a little much...I think you want 20 to 30 amps....have you gotten any over voltage codes...I went from 40 amps to 20 on my charger because 40 was throwing over voltage once in a while, and that will stop communication
If you decide to replace the power supply now or at a point in the future, I don't think you need the midtronics brand but should try to match the noise level specs of the midtronics model and set it to 13.8 VDC.
Clones never work as reliably as originals, and virtual machines often cause problems with data transfer.
I think if you are to have any hope of recovering things here, then it would be with an original VCM, and a non-hacked SDD or even IDS running native in Windows.
I can tell you from experience that clones are a bad idea. For example flashing a PCM with a clone Mongoose could take 20-30 minutes sometimes. With an original VCM it is done in less than 3 minutes.
I found that clones are often poor at data transfer on ISO and SCP networks, which are also in an X-Type additionally to HS-CAN, and SCP is critical to flashing modules, even modules only on the CAN network.
For example the instrument cluster can be considered a "gateway" of sorts, as it is connected to both SCP and HS-CAN, and during flash routines messages are sent on both networks.
So if one network is down, it can have adverse effects on the other, especially when attempting to write to modules.
IDS and SDD run fine in Windows 7 32-bit, it is what I run on all my laptops. Forget XP, forget virtual machines, no professional would ever use them.
Also with SDD you also need to run an old version of Java (6.26), and old version of Internet Explorer (IE8) it does not play well with newer versions.
You will go round and round in circles if the tools you have are not working properly.
dharry078 (07-07-2019)
