Ford/Jaguar WDS Genrad GDS3500
#101
#102
BoostedFord (03-17-2017)
#103
#104
#105
#106
#107
Dear Bob:
I recently had a 0753 and 0748 fault after a 1647 which cleared. However faults returned and stayed in gear box fault mode.
I replaced all the solenoids as I thought at 135k the indication solenoid A was one that historically on the web looked good. Started up and cleared codes and then immediately on the 2-3 shift (could have been 1-2 shift). DIfference now is that when I stop and turn the car off the codes clear themselves so to speak, and I can run the car with no fault light (unlike before) until the first 2-3 shift whereupon it goes into fault mode and sets a 0753 ONLY code
I think I installed everything correctly although on the top third solenoid over from battery there was this metal solid "V" shaped "stabilizer(??) about 3/8" x 1" that did soemthing I dont know what and I didnt get that into the correct position. Any thoughts? Could something be stuck inside the valve body? It first occurred while cold.
Thank you do much! WOuld you mind contacting me off list?
Dave david@duiutah.com
#108
#109
WDS newbie (07-11-2021)
#110
#111
#112
I have a list of the WDS software CDs I have!!!
Ford
A5
A6
B37
B40
B41
B42
B43
C4 discs 1 & 2
C5 discs 1 & 2
I also have B44 and B45 that a European member sent to me but I don't know anything about them. I don't know if they are for European models or some sort of 'patch' before the IDS introduction????
Jaguar
CD-2 (latest 'ghost disc')
JTP 759 Disc Issue 23
JTP 759 Disc Issue 24B
JTP 759 Disc Issue 28
JTP 759 Disc Issue 29
JTP 759 Disc Issue 35
JTP 759 Disc Issue 38
JTP 759 Disc Issue 41
JTP 759 Disc Issue 42A
JTP 759 Disc Issue 42B
JTP 759 Disc Issue 43
Anyone wanting to trade or obtain any of these disc, let me know.
bob gauff
Ford
A5
A6
B37
B40
B41
B42
B43
C4 discs 1 & 2
C5 discs 1 & 2
Jaguar
bob gauff
I am working on a project which I hope will eventually land me a Range Rover P38 running with an AJ133 V8 engine.
I currently own a WDS unit with Ford software, and I would like to purchase some software from you.
I'm interested in a copy of CD-2 (latest 'ghost disc'), JTP 759 Disc Issue 43.
Is the software JLR or only Jaguar?
Would I need to install all previous versions of software before I can install 43?
Regards
Rob
#113
If anyone is interested I have a working WDS for Jaguar with V43 installed. OBD cable and elusive battery cable. I have access to the docking station as well.
This was mine previously and I reacquired it.
I rebuilt the battery pack back in the day.
I do not need this as I have a VCM and IDS.
If interested send me a PM.
WDS newbie (04-19-2021)
#114
Hello motorcarman
Regards
Rob
Regards
Rob
The IDS software does have Jaguar and LR choice on the Splash Page to enter the VIN. I never chose LR cause I don't work on them.
I have JWDS_ENG_4 (CD2 Ghost) WDS 43 (CD42a and 43) on a MY DRIVE site.
Send me a PM and I will get you an INVITE to download the software.
bob
#115
The WDS was never used by Land Rover as far as I remember but they did used the IDS Rotunda VCM because we (Jaguar shop) borrowed it from Rover (across the street) when our VCM failed. Jaguar Tech Hotline told us to borrow the Rover unit to finish what we were doing and they sent a replacement VCM overnite.
bob
bob
I have a Rotunda VCM however I think it may be faulty as it goes through its power up cycle but it doesn't communicate with my pc.
That could also be my pc playing up.
Rob
#116
#117
