Ford tensioners for Jaguar???
#41
I have not heard the results of the CSI comparison yet, either, but I used the Ford primary and secondary tensioners and chains and they were a perfect fit in both the '99 AJ26, and now the 2000 AJ27 installed in the '99 car. They seem to be working fine, although I am still working through the compatibility issues with the new engine and have not had it out for a good hard run. I don't suspect they will present a problem.
#42
#43
Does anyone know if the valve cover gaskets quoted earlier in this thread (see below) also fit the Jaguar 4.0?
_____________________________________________
PART NUMBER DESC QTY LIST PRICE YOUR COST
1 2W9Z-6268-AA BELT - 553 2 47.90 95.80
2 2W9Z-6268-BA BELT - 553 2 20.51 41.02
3 2W9Z-6L266-AA TENSION 557 2 32.55 65.10
4 2W9Z-6K254-BA TENSION 555 1 53.42 53.42
5 2W9Z-6K254-CA TENSION 555 1 59.16 59.16
6 -W500301-S300 SCREW 884 4 1.50 6.00
7 2W9Z-6K297-AB GUIDE 019 2 17.60 35.20
8 2W9Z-6L253-AA TENSION 557 2 21.99 43.98
9 3W4Z-6584-AB GASKET 993 1 51.47 51.47
10 3W4Z-6584-BB GASKET 993 1 51.75 51.75
11 2W9Z-6700-AA SEAL AS 737 1 11.48 11.48
12 2W9Z-6020-AA GASKET 742 1 5.77 5.77
13 2W9Z-6020-BA RING - 871 1 3.80 3.80
#44
#45
Just thought I would pass along that I picked up the full Felpro Gasket set (FEL-PRO Part # VS50724R ) for the Lincoln LS, fully compatible with my 2001 XKR for $39.79 from Rockauto.com.
Quality and fit seem excellent. This includes both L & R valve cover gaskets, spark plug seals, and a full set of grommets. Pretty decent deal.
#46
So far, I have seen a lot of info on changing out the secondary chain tensioners. Has anybody done the primary chain tensioners in the DIY fashion?
Particularly, I would like to know if I could just unbolt the old tensioners and put the new ones in their place without loosening the VVT, secondary chain sprocket, taking out the guides, using shims, etc.![Icon Stooge](https://www.jaguarforums.com/forum/images/smilies/icon_stooge.gif)
If not, I suppose I will have to rent the timing tools off eBay.
Thanks.
Thanks.
#47
2w9z6k254, 2w9z6k254ba, 3w4z6584ab, ford, forum, gasket, jagtechohio, jaguar, number, part, secondary, set, tensioner, tensioners, v8
