Ford tensioners for Jaguar???
Old 01-04-2010, 05:10 PM
SoTxXjr's Avatar
I have not heard the results of the CSI comparison yet, either, but I used the Ford primary and secondary tensioners and chains and they were a perfect fit in both the '99 AJ26, and now the 2000 AJ27 installed in the '99 car. They seem to be working fine, although I am still working through the compatibility issues with the new engine and have not had it out for a good hard run. I don't suspect they will present a problem.
  #42
Old 01-05-2010, 03:07 PM
broathy09's Avatar
Default Ford tensioners for Jaguar
I gave them my vin number and I am under 80k and he said it would be 96.00 bucks to get it done. Im talking to another certain ford dealer employee about it also. I will find out more when I get back in town next week.
  #43
Old 04-12-2010, 03:13 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Does anyone know if the valve cover gaskets quoted earlier in this thread (see below) also fit the Jaguar 4.0?
_____________________________________________
PART NUMBER DESC QTY LIST PRICE YOUR COST
1 2W9Z-6268-AA BELT - 553 2 47.90 95.80
2 2W9Z-6268-BA BELT - 553 2 20.51 41.02
3 2W9Z-6L266-AA TENSION 557 2 32.55 65.10
4 2W9Z-6K254-BA TENSION 555 1 53.42 53.42
5 2W9Z-6K254-CA TENSION 555 1 59.16 59.16
6 -W500301-S300 SCREW 884 4 1.50 6.00
7 2W9Z-6K297-AB GUIDE 019 2 17.60 35.20
8 2W9Z-6L253-AA TENSION 557 2 21.99 43.98
9 3W4Z-6584-AB GASKET 993 1 51.47 51.47
10 3W4Z-6584-BB GASKET 993 1 51.75 51.75
11 2W9Z-6700-AA SEAL AS 737 1 11.48 11.48
12 2W9Z-6020-AA GASKET 742 1 5.77 5.77
13 2W9Z-6020-BA RING - 871 1 3.80 3.80
  #44
Old 04-12-2010, 05:51 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Yes, they do.
  #45
Old 05-03-2010, 09:08 PM
WhiteXKR's Avatar
Just thought I would pass along that I picked up the full Felpro Gasket set (FEL-PRO Part # VS50724R ) for the Lincoln LS, fully compatible with my 2001 XKR for $39.79 from Rockauto.com.
Quality and fit seem excellent. This includes both L & R valve cover gaskets, spark plug seals, and a full set of grommets. Pretty decent deal.
  #46
Old 07-14-2010, 12:25 PM
ysgeye's Avatar
Default 4.0 XJ8 primary chain tensioners
So far, I have seen a lot of info on changing out the secondary chain tensioners. Has anybody done the primary chain tensioners in the DIY fashion?
Particularly, I would like to know if I could just unbolt the old tensioners and put the new ones in their place without loosening the VVT, secondary chain sprocket, taking out the guides, using shims, etc.
If not, I suppose I will have to rent the timing tools off eBay.
Thanks.
  #47
Old 07-14-2010, 05:44 PM
test point's Avatar
Check the XK8/R Forum FAQ sticky:
The tensioner section (alphabetical) has several links to DIY discussions and pictorials.
  #48
Old 07-28-2010, 02:05 PM
tesla4all's Avatar
Sorry, posted something totally unrelated...
Last edited by tesla4all; 07-28-2010 at 06:04 PM. Reason: Unrelated to thread subject
paulyling
Mark V - X 420G
08-15-2023 09:33 PM
SD96XJ6L
01-12-2022 04:30 AM
jdzubas
10-04-2015 09:14 AM
Sprayall
09-03-2015 07:49 PM
Harry Dredge
09-02-2015 02:26 PM
Quick Reply: Ford tensioners for Jaguar???
