Front Passenger Door won't open
Welcome to the forums Lanezz,
The door latch in your XJL is a similar design to that in my XK. It's an electro-mechanical device but the interior handle has a direct cable link to the latch which should open it if the electrics fail.
The passenger door module has an individual fuse which protects no other circuit and it's possible that has blown. Alternatively, the unlock signal may not have functioned when you opened the vehicle and that door is still in locked mode. Try locking and alarming the vehicle again and then unlock it as normal.
