Fuel in oil
Received 3,910 Likes
Keith, I had a similar problem with my 5.0L engine. Now, mind ended up being the fuel injectors, but I also had to rule out the fuel system pressure sensor and the high pressure fuel pumps. Keep in mind that you can't connect just any gauge to the fuel line as it can reach upwards of 3,000+ psig. Hopefully you are getting an error code and it is talking about a failed fuel rail indication. That would point to the sensor more than likely. Not a hard part to replace and it is fairly cheap. ($80). Now, the fuel pumps were a bugger. I did them in my driveway, but I got both pumps for $400 total and took about 3 hours to do. Not a lot of room.
Keep in mind that the fuel injectors are programmed to the specific spot in the engine. So, if you replaced the fuel injectors yourself, there is a number that has to be programmed into the ECU to make sure the fuel injectors admit the correct about of fuel. If you did not do this programming, you could be getting a rich condition because of that. Besides, the fuel injectors do not control the pressure, that is what the fuel pressure sensor does and it causes the high pressure fuel pump to only engage for a certain amount of time to maintain the system pressure at a preset level (ie, a set pressure above what the cylinder pressure is).
Keithp70 (04-04-2022)
ccfulton
03-10-2013 03:23 PM
