Genrad GDS3500 WDS Docking Station
My Ford/Jaguar WDS Genrad GDS3500 docking station failed. The PTU works fine but it locks-up when I dock it. I can charge the internal battery with the docking station if the PTU is OFF but I have to undock and THEN turn it on to get it to boot up. I need to find a place to repair it or get another docking station. I remember about 10 years ago I saw the same computer and docking station at The Home Depot. The display screen had the 'Home Depot' logo and I guess they used it for inventory etc. It runs Windows 98 so it is very outdated but I used Jaguar WDS at the dealer from 1999 to 2006. Then we got the IDS and the faster TOUGH BOOK with XP Pro. I bought a Ford WDS and converted it to Jaguar But I would still like to have the docking station for the 'A' Drive, CD ROM and other features the unit needs.
If anyone knows of a repair facility that deals with the old WDS Please let me know!!
bob gauff
bob gauff
mikE-Type (05-04-2013)
It is some time ago that I played with the old wds, so not sure if I can help. At what stage does the WDS lockup when you start it in the docking station?
You could contact WDSEurope@teradyne.com, they still provide support (and sell cables/batteries), but it will cost...
I had a docking station with a bad power supply. The power transistors in one of the channels have a tendancy to fry. The PS was originally produced by a company in the UK called Power Solve. The PS is a GR250-ATX. I contacted them for a replacement, but they couldn't help.
I found a suitable ATX replacement with more wattage (250W to 300W), which is a good thing. The replacement ATX has one P8 connector with reversed polarity which is easy to convert. The twenty pin mother board connector is fully populated on the new PS and the original only uses 16 pin, but it too is plug/play. The only other connectors used are two simple +12v GND +5V power supplies to the drives and they are identical. The only feature lost on the new PS is the aux. 110VAC accessory plug.
So, if the PS is bad, I've been down that road already and have a replacement source.
BTW - I both need some WDS stuff and have some accessories for sale or trade. I need some Jaguar SW, I have some extra cables such as the OBD cable.
The PTU boots-up and operates normally if I plug in the external battery cable or on internal battery pack. (I soldered together a NIMh 4.2AH replacement battery pack as the old one was from 2001) If the unit is docked, it will charge the battery. The PTU gets through the BIOS screen and starts the 'WINDOWS 98' blue screen and then STOPS after about 3 seconds. If it is undocked and rebooted the PTU does the SCANDISK and then boots noramally. The 'A' drive ACTIVE light stays on constantly if the docking station is plugged in to 120VAC even though there is no 'FLOPPY DISK' in the drive, the CD ROM operates normally (blinks several times at startup or if a CD is loaded) The PTU does not recognize the 'GHOST DISK' or any other disk in the CD ROM. The docking station mother board has several lights that illuminate and the power supply is operating normally. I have replaced the CD ROM with a known good unit and uplugged the 'A' drive (floppy) to disconnect it from the system. The battery discharge resistors for cycling the battery pack have soot around them (They get HOT during use) but I have not removed the board for a full inspection of the circuit/solder traces. I have version 38 on the original 3.2 GB HDD (hard disk drive) in it now and I bought another 6.1 GB ATA 33 HDD. I am going to use someone elses docking station to load version 43 (the final version) so I can have both HDDs to rely on. I remember calling tech line and them telling me to go back to version 38 for some applications because the newer versions dropped some applications (newer versions added some things and dropped older little used applications) The very first software versions did a network integrety test and the newer versions did not. It's little things like that that get lost. Too bad it takes 3 or 4 hours to reGhost and load the software application every time you need to go backward to an earlier version. Thats' why I want to have different HDDs for several versions. It is easier to swap HDDs than to reload software. The WDS is good for 1995 to 2006 Jaguars so I want to get the docking station operating normally!!
stevetech
I have some Ford software disks that came with my WDS. I also have the 2 spark plug wire pickup harnesses for 4 to 8 cylinder oscilloscope function (Jaguar Never used this) I have 2 OBDII cables but 1 is inop and the one that works has a broken plug end. I have Jaguar versions 38, 42 and 43 plus the CD2 'GHOST DISK' and I might copy some earlier versions for keepsakes.
bob gauff
stevetech
bob gauff
You could try to start the PTU in the docking station without the floppy/cd rom drives attached (and maybe also without the network card), just to see if one of these could be the culprit. You could also try to start once in the docking station without the internal battery in it, and see what happens.
I have had many issues with new battery cells, and have not always been successful here. The issues ranged from system hangs, no battery charging, and WDS errors during boot up (maybe the electronics on the battery where already bad). Don’t think you have these issues, but just thought to mention it (you can always buy a new one, not cheap though).
To speed the machine up you could be an extra so-dimm of 128K or so, this will drastically speed up the system. Also I used a SDD disk (think it was from HAMA), that also helps in battery life and speed again.
You can attach these drives to a normal pc (with a 2$ adapter from china), then you can easily (&fast) make image/safety copies.
AVOS
I have already removed the PCI network card, the CD ROM and the 'A'drive ribbon cables (no change). I removed the dead battery pack and the PTU will not operate properly because of a "SYSTEM ERROR 2217" (defective or missing battery pack). I installed the new NiMh battery pack I assembled from new cells (8) with the old fuse, thermal breaker and circuit board. The PTU operates normally with the 3.2GB HDD with version 38. I installed a blank UDMA 100 slimline 40GB HDD and the PTU does NOT recognize the HDD. I have purchased a 6.1GB ATA 33 (old technology) so I can install version 43.
I will disassemble the PTU to check on available memory and see if the internal motherboard uses a normal 44 pin IDE to get a CD ROM directly to the PTU without the docking station. I know the HDD uses the 44 pin. Thanks for the info.
bob gauff
bob gauff
Dug up some info on the memory, I used the 128MB PC66 144pin sdram sodimm, should still be available, just make sure it is PC66. Just like the disks, you need old technology.
Maybe you can get pcmcia cdrom drives, but not sure if you can boot with that, but as long as you have 1 boot image, that shouldn't matter. Another option is to use a pcmcia network card. If you use the $2 adaptor you can hook you drive to your pc, so you can make an image copy for duplication, or also for coping data to the drives. I used paragon partition manager for this.
Good luck.
Good luck.
Wangstang (09-06-2011)
So if I get a larger drive I could partition a section for loading drivers and software without having to get into the operating system. Good idea as I plugged the HDD into my Pentium III laptop and it wanted to load every driver for evey peripheral it could find on the NEW computer. I'll copy the software to the new partition and load it from there. I might try a PCMCIA to USB card in the PTU if the win 98 will support the drivers. Then I could use a USB CD ROM or a Memory Stick FAT 32.
I'll keep playing with a way to communicate with the PTU without using a borrowed docking station!!
bob gauff
bob gauff
WDS newbie (04-19-2021)
I got another response from Teradyne so there is a way to get some support for these old machines.
Hi Bob,
Teradyne does the repair for WDS tablet and Docking Station...unfortunately, there is no support available..and we do not have any type of software...also, I do not think Docking Station has any type of motherboard..anyway the repair cost for docking station is (795$) and for tablet is (1195$)...
Thank you,
Vish
Teradyne Diagnostic Solutions, Inc
1800 Fairlane Dr.
Allen Park, MI 48101
www.teradyne-ds.com
Hi Bob,
Thank you,
Vish
1800 Fairlane Dr.
www.teradyne-ds.com
I found a 'work-around' for loading software onto the PTU hard drive. I bought an IDE ribbon cable adapter (two 44 pin and one 40 pin)
http://www.cablesonline.com/12in44feto44.html
from this company and looped the 2.5" HDD and the CD ROM with a power supply to the PTU motherboard all laid out on an insulated work table top. IT WORKS!!!!
I have A6-B43-C5 Ford software on a 4.3GB ATA33 HDD and CD2 and version 43 Jaguar software on a 6.1GB ATA33 HDD so I can swap hard disk drives to have either Ford or Jaguar WDS. It takes around 4 hours to load the software so this saves ALOT of time. I tried a UDMA100 40GB HDD and the old Pentium I 233mhz computer won't recognise the drive (too new)
It's a good way to have Ford and Jaguar software on the same WDS (just swap the HDDs as it takes 5 minutes)
bob gauff
bob gauff
Edit:
I have 7 Ford Discs, but some dups.
A6
B39 (2 copies)
B40 with C5-1 and C5-2
B41 (2 copies)
B42
Ideally, I'd like to trade you copies, but would need some help getting copies made.
I have disc 23, 25, and 29 right off hand. the last release for Jag was disc 43. Im sure i can find that copy or 42, which is pretty much the same. email me: lanemeyer@hotmail.com These are originals since I dont need Jag discs. Copies of the ford ones are ok, as long as they work. I just need the latest disc for ford.
The following 3 users liked this post by motorcarman:
