Genrad GDS3500 WDS Docking Station
Old 12-05-2014, 09:25 PM
Ozone240's Avatar
I was hoping you might respond. Pm coming your way shortly. Thanks a bunch!!
  #282
Old 07-23-2015, 06:18 AM
oldsalt 3's Avatar
Unhappy GenRad
Hi I wonder if someone could help me please,
I am restoring a GenRad GDS 3500 Part no 418-F224 Ref 5 after a Harddrive crash.
The new drive was formatted and partitioned with Red Disc A2, then Blue Disc B-41, followed by Black Disc's C5-1 and C5-2, I was then asked to insert System CD A6 alas no CD A6.
I have searched the box of CD's but can't find a CD A6. After searching through the workshop I found a note which had GDS 3500/System A6/CD-B44A. Release Date 24/07/2006, Calab C5.
It looks like I now have two CD's missing, no CD-B44A in box.
CD,s I have are RED A2,B-39A. BLUE B-34,B-35,B-36,B-36A,B-37,B-38,B-40
and B-41. BLACK CD's C-1,C-2,C4-1,C4-2,C5-1 and C5-2 all FORD CD'S
Hope someone can help.
  #283
Old 10-25-2015, 01:28 PM
rdbuildr's Avatar
Default I need WDS B-203*B-280 cable plug pinout
Hi, Im trying to figure out the occupied pins in the cable plug end for the WDS, looking at it long way the first row should have all five holes occupied and so I just need going from left or right each 5 pins in the remaining 7 rows... thank you
  #284
Old 12-07-2015, 11:36 PM
Received 4,453 Likes on 2,426 Posts
Since this is where all the WDS guru's congregate https://www.jaguarforums.com/forum/p...5/#post1361061
Anyone?
  #285
Old 12-13-2015, 10:39 AM
Gijzzy's Avatar
To get my Jaguar PDU project finally working I bought a spare Ford FDS2000 from an advertising on the internet with some unclear pictures but I could see that the part I needed was there. I bought it and went to pick it up and to my surprise the guy included a WDS! I already have one working with Jaguar software, and now I will make this one as a backup. I had a lot questions about upgrades, power supply, etc. but it took me 3 evenings reading the whole tread and taking notes besides and most of them are answered in this topic!
I just want to say thank you to you all!! Great topic!
I still have some questions but first I will make a new power supply because mine is missing, upgrade the RAM and HDD. Than I will be back.
If anyone has problems with there FDS2000 or Jaguar PDU CD drive contact me as I ended up building replacement boards for the PDU to get mine working.
Attached Thumbnails Genrad GDS3500 WDS Docking Station-1430673224917-214426060.jpg
  #286
Old 12-14-2015, 01:57 PM
Gijzzy's Avatar
Ok, first question:
Originally Posted by xjrguy
3548-5250-00 = B250 CPC Diag Cable, if memory serves, it's for round diag connector on '93-'94 XJ40 and XJS OBDI models
3548-5251-00 = B251 PM4 Diag Cable, for '90-'92 4.0L OBDI models
[WDS was intended to at some point work on these OBDI cars, but it never happened]
Are these cable useless because WDS doesn't work on these models? Or is it worth looking for them? (I have got two B251 I believe but missing the B250 cable)
2. I understood that for the extra memory only PC66 would work, but I just found a 64MB 133PC and it is working (still looking for a 128)! Can anybody explain?
Memory used:
(Compaq 64MB PC133 133MHz non-ECC Unbuffered CL3 144-Pin SoDimm P/N 239189-001)
  #287
Old 12-15-2015, 01:38 AM
JagV8's Avatar
Received 4,515 Likes on 3,927 Posts
Generally if it's the same as regards ECC and buffering (*) - and voltage - and fits (this usually/always means the voltage is OK) then it will work. Looks like you've fitted faster memory which is harmless as its extra speed will just be wasted (not used) I think. The extra RAM will really help, I expect.
(*) most PCs want non-ECC & unbuffered, but you have to check
  #288
Old 12-15-2015, 11:22 AM
Originally Posted by Gijzzy
Ok, first question:
Memory used:
I wouldn't sweat the B250 OR the B251 cables. They never wrote the OBDI systems into WDS software. Early on they said they were going to, but they never did. We just had to beg, borrow, cheat & steal what we could to keep the older PDU going as long as we could.
Our good man, Motorcarman is the guy to ask about the memory. He has what will & won't work dialed in pretty much.
Cheers,
  #289
Old 12-15-2015, 01:59 PM
Gijzzy's Avatar
Thanks for the reply!
Good news and bad news.
First:
I made a new power supply as mentioned on page 9 of this topic. A 'off the shelf' power supply and cut the 3 orange (3V) wires, and made a 16V power supply to the 6 pin P8 plug. I used a 15V 8A Toshiba laptop supply which is giving 15.49V so I assume that would be ok. But the problem is the ATX doesn't start up. No fan and no power to CD drive and floppy drive. What do I miss? Or would my motherboard be faulty?
Also I don't get any lights on the WDS that there is any power, not sure if it has to with only 16V.
Second:
I insert a empty 20GB hard drive and it is being recognised by the WDS. Next step, how do I get the ghost software starting to install from the black screen? (on a working docking station of course)
I appreciate the help!
Attached Thumbnails Genrad GDS3500 WDS Docking Station-dsc_0044.jpg   Genrad GDS3500 WDS Docking Station-dsc_0045.jpg
  #290
Old 12-15-2015, 07:02 PM
motorcarman's Avatar
Received 8,045 Likes on 4,853 Posts
The GHOST CD (CD2) is AUTORUN...................
The docking station has the CD ROM drive and when all is powered up, the CD2 (GHOST) is automatically booted.
It OVERWRITES the HDD and partitions for WDS software.
When the WDS is docked, please ensure that all the ORIGINAL hardware is in place. No Printer, No extra board in the PCI slot.
If no power to the docking station, then you have a problem somewhere.
bob gauff
  #291
Old 12-16-2015, 05:40 AM
JagV8's Avatar
An ATX PSU often (always?) needs to know it's meant to power on. There's some sort of sense circuit for that - details on the net how to fool it I expect (it's to do with the "power on" switch on PCs now being low voltage not mains volts).
  #292
Old 12-16-2015, 11:51 AM
Gijzzy's Avatar
I took the ATX out of the base station and tried to trick it as described on the internet (put a paperclip between the green and a black wire) but no reaction. I just killed an other PC to take the ATX out and now the base station is working! Now waiting for my Jaguar ghost CD witch will be in the mail next week, so I can program the Jaguar software on a 20GB hard drive.
  #293
Old 12-20-2015, 03:00 PM
Gijzzy's Avatar
Error: Partition 1 set to small, min size=2%.
I formatted the hard drive (FAT32) and the drive isn't partitioned, so partition 1 = 18+ GB. Any ideas?
I can't put the Ford software (incl. B45) on the 4GB because the disc is to small and as I read for Jaguar you need min. 6 GB so I hope I can get my two 20GB hard drives to work. (how many do you need for AM?)
Maybe make partition 1 8GB?
  #294
Old 12-20-2015, 06:11 PM
The only 'modern' HDD (Non ATA 33) that I have able to get the WDS to recognize is a 8gb SSD Compact Flash card with a 2.5" 44 pin IDE adapter.
It will work most of the time but when I tried to load several in succession the PTU would NOT work. The screen had the boot failure and wanted a suitable disk installed, then TRY AGAIN!!!!! I plugged it into another PTU and it was recognized again.
Pentium I, 233mhz computers will usually only recognize 8.4gb HDD MAX.
You can install a greater capacity HDD but unless you partition, it will be wasted.
You don't need to partition the common ATA 33 HDD as the CD2 (GHOST CD) will do all that for you. (The Ford equivalent is A6)
The best ATA 33 HDDs are 4.3 to 8.4 as they will be large enough capacity for all Ford, Jaguar, Mazda, and Aston Martin applications.
The 8gb Compact Flash Card with the 44 pin adapter should also work but can be 'iffy' and be somewhat temperamental.
I had a few 40gb and 20gb 44 pin HDDs for more modern laptops and NONE would work in the PTU. Only the ancient 2.5" low capacity 44 pin drives are reliably compatible.
When I install a NEW unformatted HDD the GHOST CD just does all this automatically. (format and partition) Then loads Windows 98.
bob
  #295
Old 02-28-2016, 05:14 PM
soerensen's Avatar
Default Problems with PDU and WDS
Hi!
I'm having troubles with my two Diagnostic Units PDU and WDS
PDU
I get the PDU in pretty dusty condidtion. Drained batterys and a faulty Sony CD ROM.
I got a new Atapi Board from the Member Gijzzy. Now the PDU can read the Data from the discs perfectly.
But because of the missing battery i can not connect to a car.
My question is: Can somebody tell me the Specifications for a replacement battetry?
I try to make Photos of the PDU tomorrow. I hope i have all Parts that i need to connect to a 2000 XK8 A1347*
WDS
I also get a GenRad GDS3500 (Ford) which i believe is complete. 'Only' the battery is fauly. In settings the WDS says that the battery is charging, but is showing 0% all the time.
I tested various Fords and the WDS seems to work perfect.
But i dont have the Jagur CDs Ghost CD2, 42a(+b?) and 43.
Is there any way to get the Software?
And: Can someone tell me the specifications of the WDS Battery? I read somewhere 9.6V. Is that correct?
I hope someone can help.
Thanks!
  #296
Old 02-29-2016, 03:55 AM
soerensen's Avatar
Default Pictures
Hi.
Here are some Pictures of the Devices, Cables and Books i have.
Hope this helps
Attached Thumbnails Genrad GDS3500 WDS Docking Station-1.jpg   Genrad GDS3500 WDS Docking Station-2.jpg   Genrad GDS3500 WDS Docking Station-3.jpg   Genrad GDS3500 WDS Docking Station-4.jpg
  #297
Old 02-29-2016, 04:43 AM
soerensen's Avatar
Default PDU Battery Polarity
Can someone tell me which is positive and which is negative for the Batterypack?
Dont want to mess it up
  #298
Old 02-29-2016, 04:54 AM
Wow that's quite a collection!
Software for the WDS is no problem and it's a far better tool for a 2000 XK8. I'll send you a PM.
The original PDU (Ford FDS2000) it's really only useful for the XJ40 and XJS prior to 1995, a museum piece. The WDS is so much better for 1995 onwards vehicles.
soerensen (02-29-2016)
  #299
Old 02-29-2016, 01:29 PM
soerensen's Avatar
OK, i got the ISO Files from Cambo (again, thanks ) and the installation fails at CD3 v43 at 92%...
It seems i got an early Ford WDS Model with a 3.2GB HDD
Now i ordered 2 x 6,4 GB ATA33 for Jaguar and Ford.
Cant wait to see it running with the right Software
  #300
Old 03-01-2016, 02:47 PM
Lady Hirsel's Avatar
Hi Florian,
I have made a picture of the battery connector from the PDU
The WDS and the PDU are great tools for your XK8. Also we have PDU,WDS and IDS/SDD for our jags ,my favourite tool is the PDU.
If you need help to get all running just write,we are in Kerpen Germany.
Tanja
soerensen (03-04-2016)
Quick Reply: Genrad GDS3500 WDS Docking Station
