Genrad GDS3500 WDS Docking Station
#361
Hi Bob,
thanks for your suggestion. I actually thought in the same way and ordered a PCMCIA2USB Card yesterday. It was just 6 from China and will arrive after Christmas.
Upgrading will be a Problem for the 3GB disk. But I received another 4 GB disk yesterday and set it up without deleting anything, and it went through without comments.
But the higher operating system will go, the more resources I will need.
I don't think WinME will be very fast on the Pentium at 240MHz.
Best regards
André
Best regards
André
If you were able to get Jag 43 up and running on a 4.3GB HDD your very lucky. I've only had success with sourcing 6.4GB HDD's.
I sold off my WDS stuff bit i might have 1 or 2 6.4GB HDD's left that are plug and play in the WDS.
#362
Hi Bob,
hard drives of that size seem hard to find - to a reasonable price.
I tried the 20GB drive but booting stopped right under the BIOS table. So I guess it has nothing to do with partitions.
Additionally it is funny enough that the System did not start as I shifted space with a partitioning tool from D: to C: . Very strange.
The 4.3 GB drive worked fine however.
![](http://jaguar-hilfe.de/bilder/beitraege/2016-12/2016-12-03_PTU54.jpg)
So if the 6.4 and the 8GB do work I will be looking for them too.
And of course the compact flash cards. The card adapters are about 2€ from the Chinese market. But they will take some time.
Did anyone of you do some measuring on the cables for the "B-port" ?
Meaning which pin goes where from plug to plug.
Background for me is that the B203 / B280 seem hard to find. The Ford cables are more frequent. If I now know the pin setting of either one I could set up an adapter between OBD-plug of the cable and OBD-socket of the car.
Best regards
André
Best regards
André
#363
#364
Dear Andre,
First of all congratulations on your extensive report on your WDS experience. Impressive how you struggled around the issue of not having a docking station.
On the issue of the cables - I don't think the cables are just 'connectors' between the OBD2 pin layout and the WDS. Unlike the 12v power cable (of which you found the layout in an earlier post) I believe the B203 and B280 or B259 cables must have some kind electronic circuitry board inside of them. If you measure pin connections, you will find that some connections will have 0 ohms resistance, while others have values of several hundreds of ohms. You will also find that current direction is important - implying that diodes might be involved and I also believe capacitors are involved because you can charge the cables a little bit. I never had the guts to try to open one of my cables (too expensive) and I never could find anywhere on the net someone else who did, so I don't know if I'm correct. It is challenge to everybody :-)
Good luck with your WDS - if you have questions - please ask...
#365
Dear Yvo,
thanks for your comment.
What a pity
. I had hoped all the electronic would be on the Instrument board inside the PTU. I have several (Clone-) Mongoose cables, but they are pretty easy to dismantle.
Now I will have to do some testing with a Ford cable of a friend of mine, if I do not succeed to get a B203/280 until my cat comes back in March.
There is a General layout of OBDII cables for Ford/Jaguar/Mazda/Toyota which differs slightly on some pins. It might be possible to plug a "redirector" between ODB-plug and ODB socket.
But I fear that the cables are coded by Pins at the PTU, so that this device will directly detect, what is connected.
regards
André
What a pity
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
regards
André
#366
Hi guys,
You may have answered a queery I have, I have a B280 cable which works ok so know unit is working, and I have tried to make up a B203 cable using the correct pinout details as described earlier on on this post (and confirmed by checking a complete cable) but up to now I have tried half a dozen times to make good the plug set up but it does not get recognised by the PTU as keeps asking to connect cable to B port, so there may be something in your theory that there are some hidden diodes/resistors in the cable make up.
The cable I am attempting to convert is a later VCM cable that only had 20 pins which I have carefully liberated from the plug but there isn't anything extra at that end so if it is it could be in the 16 pin end.
hope you can find out as I was thinking that it was me.
regards and awaiting further developments
rrosscoe
rrosscoe
#367
update to Cables again,
thought I would re check my B280 cable so got the test meter out,
Right what I found was this,
40 pin to 16 pin as in picture below (thanks to I think motorcar man for pic)
![](https://www.jaguarforums.com/forum/data:image/png;base64,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)
1 = 0.8 - 1.0 Ω
8 = 0.8 - 1.0 Ω
7 = 1.0 Ω
15 = 0.8 - 1.0 Ω
16 = 1.4 - 1.6 Ω
10 = 1.0 Ω
2 = 1.0 Ω
5 = 0.6 Ω
12 = 1.0 Ω
13 = 1.0 Ω
5 = 0.8 -1.0 Ω
16 = 0.6 Ω
5 = 0.8 -1.0 Ω
4 = 0.5 Ω
so it could be small differences in my connections to the pins that give small deviation in resistances, OH and I did check them both ways to check for diodes, so it would appear that they are just cables after all, which does not help me in my quest to make a cable up.
still trying
regards
rrosscoe
thought I would re check my B280 cable so got the test meter out,
Right what I found was this,
40 pin to 16 pin as in picture below (thanks to I think motorcar man for pic)
1 = 0.8 - 1.0 Ω
8 = 0.8 - 1.0 Ω
7 = 1.0 Ω
15 = 0.8 - 1.0 Ω
16 = 1.4 - 1.6 Ω
10 = 1.0 Ω
2 = 1.0 Ω
5 = 0.6 Ω
12 = 1.0 Ω
13 = 1.0 Ω
5 = 0.8 -1.0 Ω
16 = 0.6 Ω
5 = 0.8 -1.0 Ω
4 = 0.5 Ω
still trying
regards
rrosscoe
#369
Hi rroscoe,
geat job you did.
Now let me give you the pin-assigment of the OBDII socket/plug for the Mongoose Pro
![](http://jaguar-hilfe.de/bilder/beitraege/2016-12/2016-12-09_OBDII.jpg)
Hope that helps.
Did you check also, if there is a connection inside the 60-pin-plug that might "code" the cable ?
Best regards
André
geat job you did.
Hope that helps.
Best regards
André
#370
Thank's Andre,
will have good look and see what is missing from my 16 pin pin-out taken from jaguar wiring dagram but I would have thought that if pin 1 on 16 pin goes to the top left on drawing and the other ones go to there respective number then if it was JUST a cable then my attempt to make one up would have worked, however as said I have tried half a dozen time to make the correct plug but just get "Connect plug to port B" so something is not quite making a connection, will keep trying.
regards
rrosscoe
regards
rrosscoe
#371
Hi rroscoe,
just put in another question into my post (but you already posted in parallel)
"Did you check also, if there is a connection inside the 60-pin-plug that might "code" the cable ?"
Anyway, I will get my cable from England within the next two weeks and will then be able to do some more Investigation on that one.
cheers
André
cheers
André
#372
#373
WOW!
Good score!
Can you do me a favour, the WDS that's sitting on the red toolbox, is there a brand or part number for that toolbox? I don't have a trolley for mine and ive been trying to find a roller toolbox for it, but you know the docking station is a bit of an odd size, I have not been able to find one that it fits on nicely...
Good score!
#374
#375
Hi Bob,
we have the B203 and the B280 on board as well as some of the other cables.
I already did some testing with pin-correlation.
I tested the B280, B207, C201 and C202. I figured out that for the B-cables it seems to some Sudoku-Puzzle, as different cables seem to use different pins.
Hope to figure out some kind of Matrix to make it easier to rebuild them.
@Cambo
I will ask my friend for the red Toolbox.
best regards
André
@Cambo
best regards
André
#376
Hi Andr'e,
Nice find on the units and cables, just in case I cannot get my B203 to work if you find a "spare" one amongst all your goodies can you put it aside for a while in case I have to end up buying one (ooh come over all funny) and if you manage to get the matrix it will help everybody I think as they are a bit of a mystery, just as an after thought do you know a supplier for compatable pins for to cables as the original ones I have been using have lost there grip, I have tried IDE cable pins but they are incorrect as have some others I have tried from Maplin, I think the problem is that they have no support out of the 40 pin socket that is why they get loose and proberly do not make positive connection.
regards
rrosscoe
ps merry christmas to all
regards
rrosscoe
#377
Well yesterday I dug out my old Windows 98SE UPDATE disc and loaded it onto the PTU. I chose SAVE FILES so it can be UNINSTALLED if I need to.
All went well and then I unplugged the HDD (8GB compact Flash with adapter to 44 pin) and installed it onto a USB to 44 pin adapter. I plugged the USB into my DELL laptop Windows XP and did a DEFRAG. It is faster to let a 2.4 GHZ laptop DEFRAG than to let the Pentium I 233 MHZ try to struggle though it (10 min instead of HOURS).
A NEW install is NOT an UNFRAGMENTED disc. Even GHOST, 42a and 43 install leaves fragments.
The 98SE is supposed to be able to recognize USB so I ordered a PCMCIA USB to try in the PTU. Flash Drives are handy.
I also ordered a PCMCIA Compact Flashcard adapter. I am hoping to get a new/defragged install and GHOST the install onto several 8GB CF to have as spares.
Anyone tried the 98SE upgrade??
I'll report back when the PCMCIA devises get here.
bob
bob
#378
Dear Bob,
that's exactly what I want to do.
I tried that with a reinstall of Win98 SE over the existing System. But although I used a complete bunch of recommended Parameters with the Setup.exe it installed into a new Folder ignoring the existing System.ini.
At least I now received the IDE-to-CF Adapters and was able to install everything even onto a 16GB card. So why the hell does it not accept the bigger harddisk ?
I am also waiting for my PCMCIA-to-USB Adapter from China and will obviously have some Trouble to get the richt Drivers for that.
Is there a possibility to create an ISO-file from your Update-disk ?
Cant seem to find it .
I will Keep you updated on my Progress here.
(Please excuse all the nouns in capital letters - auto-correction )
Best regards
André
Best regards
André
#379
I can create the .iso file but I would need a site to upload to.
A full install will likely not work. The 98SE upgrade needs to have 98 already installed.
It just upgrades the Windows portion and leaves TABMAN and GDS Shell intact.
I have not received my PCMCIA adapter yet to try the USB function.
The one thing that is annoying about the upgrade is that the SHUTDOWN 'hangs' on the 'WINDOWS IS SHUTTING DOWN' screen.
I usually just undock the PTU and unplug the battery to shut it down when I see it not responding.
I remember it did the same thing more than 15 years ago when I upgraded my Sony VAIO from Win 98 to 98SE. I had to hold the power button until it shut down.
I still have old disks from 'the-old-days'.
Widows 98 Full Install
Widows 98 SE Upgrade
Widows 98 SE Full Install
Widows ME Full Install
Widows 2000 Pro
Windows XP Pro
I'll create the .iso soon.
bob
Widows 2000 Pro
Windows XP Pro
bob
#380
