Thank you, i see the pictures are in my album now (uploaded several times) but now i can't move them to this post - can i mark them for public view somehow ?
Because my post count is still too low to upload some pictures of my Iveco IT2000 / GDS3500 tool with some details about the USB connector and surrounding parts i add this post to reach my minimum post count (10 posts ??)…..
I already ordered some CR2450 batteries + battery holders to replace the Original CMOS battery - i assume the type number is correct when i look at the size of the battery ?
Can i just put it in parallel with the present BIOS battery to avoid further disassembling of the touch screen ribbon cable and other connectors ?
i just tried to upload some pictures from my album but i still don't succeed - can somone explain what conditions have to be met before i can post pictures ?
i just compared the region of the USB connector of my Iveco GDS3500 with this picture of a WDS unit but there are slight differences regarding the pcb layout, if someone needs values of certain components i can check them if unreadable on the pictures....
Gert
This is really interesting! We always thought it would be possible to have a USB connector at that space on the board - and there it is! I'm going to compare your pictures with my pictures of the Ford WDS - looking if anything else is different....many thanks!
Well today i hit the jackpot !
i was able to buy a complete WDS kit with dockingstation , PTU, all cables, cd's doumentation + a complete IDS system + a vintage FDS2000 system also with all cables, cd's, documentation, folders etc.
All items are in mint condition and most tools were packed in their Original boxes !
It took me a ride to Belgium but it was well worth the effort, my cable problem is solved at once now !
It will take quite some time to do a inventory of all included stuff but it's a nice job !
I will let you know when i find any rare parts or software, i'm in the right spot on this forum...…
i just tried to power up the PTU in the docking station but it seems the power supply only supplies power for 1 second and then it shuts down.
Is this a known problem with the docking station and has someone found a solution for this fault ?
Can i exchange the power supply with another one from an old computer ?
The PTU gives me the 2217 fault code due to the dead battery - i will exchange that first to see how the machine works with a fresh battery….
Hello Bob, thank you for your reply- i already found some answers in this thread in the meanwhile, right now i'm charging a fresh battery pack and i will check if it makes any difference…..
I would pay an enormous amount of money for all that you have!!!!!!!!!!!!!!! Congratulations on the find. I hope you help locals with diagnostics!!
