Genrad GDS3500 WDS Docking Station
Old 08-25-2020, 07:13 AM
Gijzzy's Avatar
A T4 unit is hard to find (trust me, I know ), but luckily there are several alternatives like Lynx, Hawkeye, Auto Enginuity to name some. But I guess you are better off on a Land Rover forum for that.
  #542
Old 08-25-2020, 05:28 PM
wh_4741's Avatar
After 8 years of sporadic usage, the screen is now giving me some trouble. When powering on, the screen lights up, but shows vertical lines. Wondering if anyone has seen this symptom before and/or been able to fix it? Thanks so much!
Vertical lines
nrtoto (05-26-2021)
  #543
Old 10-05-2020, 03:09 AM
pancyber's Avatar
Thumbs up
Ford CDs for Genrad GDS3500 re-uploaded here: https://drive.google.com/drive/folde...Bt?usp=sharing
Feel free to contribute if you have anything to share
  #544
Old 10-14-2020, 08:02 AM
wh_4741's Avatar
Hello, just wanted to provide and update on my screen issue. It turns out that the battery was the problem.
I rebuilt the battery pack using the following resources:With the rebuilt battery pack, the lines on the screen are gone, the screen is brighter than it was before the screen 'line problem' started. And best of all, can now undock the PTU without it turning off!
Here it today
motorcarman (10-14-2020)
  #545
Old 10-18-2020, 09:48 AM
Vee's Avatar
Vee
Vee is offline
Received 1,562 Likes on 1,213 Posts
I rebuilt mine and simply soldered the nickel strip to the batteries...
motorcarman (10-18-2020)
  #546
Old 10-18-2020, 10:29 AM
motorcarman's Avatar
Received 8,084 Likes on 4,876 Posts
Soldering worked for me.
  #547
Old 12-26-2020, 10:13 AM
rrosscoe's Avatar
Hi mattvie,
did you manage to get any information regarding the pin outs for the B203 cable?
rrosscoe
  #548
Old 11-25-2021, 12:34 PM
Spokesy's Avatar
Originally Posted by xjrguy
PM sent......
Hi I’m also in need of AM CD002 can you help?
I have CD013 but no operating system post HDD dying. Is this something you could share/sell many thanks
  #549
Old 11-25-2021, 02:52 PM
Spokesy's Avatar
Originally Posted by y.roos
Most important cables are:
A204 is battery cable - very useful when working on car as WDS with good battery is empty in 20 minutes.
B203 is the OBD cable for Jaguar, Aston Martin and older Ford models - for the OBD body socket of a DB9 you will need and extra adapter.
B280 is the OBD cable for newer Ford models.
If you own an older model DB7 you might need a special cable (number I will have to look up) which is not on your list.
I've sent you a PM regarding Aston Martin Software. Also I have developed a multi-boot WDS 40-60GB HDD (or even on 80GB SSD) where with just one HDD or SSD (very stable) you will have a complete Aston Martin, Jaguar and Ford/Mazda system on just one WDS device.
Hi sorry I can’t seem to PM you,
I’m interested in one of these HDD or a copy of a ghost disk CD002 for Aston Martin shipping to the U.K. let me know the best way for us to make this happen? thanks
  #550
Old 11-26-2021, 01:18 PM
y.roos's Avatar
PM send - will arrange a download link for you.
  #551
Old 11-26-2021, 01:56 PM
Well I have 3 Genrad PTUs and aholbro1 keeps one that I lent him. (because he has 7 or 8 Jaguars)
He showed up last week with the PTU because it would not BOOT UP. (dead)
I have one that I use and one that the screen is dark. I can use a VGA monitor but you have to use a keyboard/mouse or GUESS at using the touch screen.
You can poke at the screen and guess where the pointer will be on the remote VGA monitor.
I decided that I needed to combine the two and make one good unit from the two with 'issues'.
The screen from the dead unit was fitted to the working but 'blank' unit and now I have two working again.
If anyone has questions about the 'innards' of the PTU, ask me now because in a few weeks I will have forgotten most of what I remember now.
I don't know what to do with the 'dead' unit but I will save it for parts I guess?
  #552
Old 11-27-2021, 12:50 PM
Received 1,423 Likes on 1,066 Posts
I have a good PTU but won't seem to boot up properly w/o the docking station. I tried doing so by hooking up to 12V battery. Any clues? Thx
  #553
Old 11-28-2021, 08:26 AM
It should boot with either the A204 or the OBDII cable plugged into the car socket. It will get power both ways.
Maybe your NiMH battery is faulty?
I use the docking station all the time but aholbro1 only uses the PTU that he keeps at his place.
  #554
Old 11-28-2021, 11:18 AM
xalty's Avatar
Received 1,060 Likes on 851 Posts
my 204 cable was hanging by a thread. might be why it doesn’t start over 12V.
if anyone lost or broke theirs, you can get a new one it’s the same as the VMM A401
motorcarman (11-28-2021)
  #555
Old 11-28-2021, 08:49 PM
I'll try booting it via OBD2 - I'll check on the NiMH battery. The battery pack was rebuilt by me before selling the PTU. No error code for that when booting the PTU
  #556
Old 12-18-2021, 01:28 PM
xalty's Avatar
I have a PTU that can’t talk with vehicles anymore. diagnostic menu says “failed to start the vehicle communications interface”.
Everything else including the touch screen is fully functional. If anybody needs parts let me know.
  #557
Old 12-18-2021, 02:29 PM
I have a failed computer and screen with a good VCI. (back half)
Where are you located xalty?
  #558
Old 02-03-2022, 04:03 PM
A_Mechanical_Mess's Avatar
Default Where exactly does the 16 volts need to be wired?
Originally Posted by Cambo
Finally got my WDS. Bad news is it had a rough trip across the US and then across the Pacific...
Took a few hits in transit (i'd say more hits than Elvis) and the docking station is a bit beat-up now. The cosmetics don't worry me, but the power supply is dead as my music career...
Had to boot it up on the battery cable, the hard drive seems to have suffered from the knocking around.
I didn't have a keyboard on hand with the PS/2 connection, picking one up tomorrow. So the scandisk ran and then stopped at 350'767 clusters, twice.
I got a few spare hard drives from abonano which is nice, if I can get the docking station going I'll start going through them.
The power supply is totally dead...
It's the original from 1998 so you could say it's had a good run, it would have never ever been switched over to 230V either so maybe it was all too much...
I came across a good replacement NEW ATX Computer Power Supply Supplies PSU 400W for PC Desktop Tower Case Unit | eBay which will fit perfectly in the case, and it gives me an on/off switch too! I have a spare 16V laptop power supply so i'll get that hooked in to charge the battery...
Getting there slowly lol...
I have been trying to install a new power supply and have the same issue i got the laptop 16v power supply but have no idea where it actually needs the 16 volts going.
  #559
Old 02-08-2022, 11:15 PM
xalty's Avatar
orange hot black ground. big white connector on right side of the board
another professional solution is to throw the whole thing in the garbage can and use a power supply on the bench to run the cd drive and install software
motorcarman (02-09-2022)
  #560
Old 02-09-2022, 08:35 PM
Someone posted years ago on this site but I don;t remember who/when.
Quick Reply: Genrad GDS3500 WDS Docking Station
