Help with door dents.
Received 9,470 Likes
Um, I have found that an ounce of prevention etc., as in, I Always park my Jag FAAAAAR away from ALLL other cars in the lot. Out in the West 40 as it were.
I know that doesn't help with the dents you already have, but you could contact a local paintless body repair shop. They might have a trick or two to at least minimize those door dings.
I've moved it from Off Topic to General Tech Help and left a permanent redirect so it appears in both forums.
I'm interested to hear of skills and techniques other than resorting to a PDR technician.
thank you. I’ve seen a few things on YouTube involving heat guns, boiling water, and suction cups. I may try it myself today. Will def report back.
GGG (03-09-2018)
If you have an outboard boat motor you know what the ear, water muffs are that you connect a water hose to so you can run the motor. Anyway take the rubber cup that does not have the hole in it off, wet it put it on the dent and grab the nipple with vise grips as the suction is really very, very strong and pull. After you pop the dent out you may have to free the cup by lifting the edge of the rubber cup.
I have not seen a dent yet that it wont remove, big or small.
Can be bought at wal-mart or boat supply store, cheap.
Thor78
07-23-2013 10:51 AM
