Jaguar Forums File Download Area, Folder Index
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Please find below a master index of the folders that we currently hold in our Mediafire hosting account.
This method of hosting has been newly created to allow the storage of files that are generally too large to be held directly within the forum.
Simply click on a 'Folder Link' to be taken to that folder.
Then click on 'The Folder' to be taken to its contents. (in many instances there are sub-folders, simply continue drilling down)
You can then download any of the files that you may require.
If you require files from more than one section, simply repeat the above from within this thread.
We will endeavour to keep this index up to date, but the folder contents may have been updated since your previous visit, you will need to check for new content.
There are literally hundreds of individual files available for download (far too many to list individually) so a bit of effort is required on your part.
Happy hunting.... Thanks go to all the members who have contributed to this.
Jaguar Fault Codes
AJ6 Engine Management Diagnostic Guide
Interesting Reading
Classic Jaguars
X Type (off forum file download area, all users)
S Type (off forum file download area, all users)
XF (off forum file download area, all users)
XJ40 (off forum file download area, all users)
S1, 11, 111, XJS (off forum file download area, all users)
XJS / XJ40 / XJR TSBs
XJS Buyer's Guide
X 300 (off forum file download area, all users)
X 308 (off forum file download area, all users)
X 350 XJ8 2004-2010 (off forum file download area, all users)
X 351 (off forum file download area, all users)
XK8 / XKR X100 (off forum file download area, all users)
XK X150 (off forum file download area, all users)
Technical Training Guides
hp24 ZF Files
6hp26 ZF Files
JTIS21 CD download with instructions
XJ_X351_Sunroof_TSB_JTB00368V2
Jaguar Fault Codes
Interesting Reading
Classic Jaguars
XJS Buyer's Guide
hp24 ZF Files
6hp26 ZF Files
The following 280 users liked this post by Translator:
-Greg- (02-02-2017),
00franky00 (08-10-2014),
03s-type_sport (04-10-2017),
04oldschool (11-15-2014),
3JagMan (07-10-2015),
and 275 others liked this post.
The following 17 users liked this post by Translator:
ALProgress (06-28-2015),
camillo (05-22-2019),
CharliePar (02-03-2018),
Dallas Rockford (06-22-2016),
davidladewig (02-22-2015),
and 12 others liked this post.
The following 8 users liked this post by Translator:
Don B (07-13-2014),
frankiethebear (04-16-2015),
jjd247247 (02-21-2015),
Orthodixie (03-26-2017),
ragman1171 (08-07-2014),
and 3 others liked this post.
UPDATES
1. Jaguar Service Training Course NP04 - New XJ 2004 MY Technical Introduction
Air Suspension Section (thanks to Don B)
http://www.mediafire.com/view/7rdkgg...on_Section.pdf
2. X308 Electrical Troubleshooting Guide Rev. 2.1 (thanks to avt007)
http://www.mediafire.com/view/qqv1uy...leshooting.pdf
UPDATES
1. X308 Electrical Troubleshooting Guide Rev. 2.2 (thanks to avt007)
http://www.mediafire.com/view/j4irvg...g_Rev._2.2.pdf
The following 3 users liked this post by GGG:
UPDATES
1. XJ6 Handbrake: Extract from Jaguar XJ6 Service Manual ( thanks to o1xjr)
http://www.mediafire.com/view/gbauus..._No._E.155.pdf
The following 4 users liked this post by GGG:
UPDATES
1. Battery 101 for S-Type Jaguars (thanks to Cat_as_trophy)
http://www.mediafire.com/view/hjfrng...ype_Jaguar.pdf
2. PowerTech PRO smart Charger (thanks to Cat_as_trophy)
http://www.mediafire.com/view/3i1943...H_(AUS&NZ).pdf
3. C-Tek Smart Charger in the UK (thanks to Timmyboy)
http://www.mediafire.com/view/anl78s...K_(UK&EUR).pdf
4. Deltran Battery Tenders in USA (thanks to Jumpin' Jag Flash)
http://www.mediafire.com/view/t81uz6...ender_(US).pdf
5. Deltran Battery Tenders in Canada (thanks to Mikey)
http://www.mediafire.com/view/42754o...nder_(CAN).pdf
All available in the S-Type 'HOW TO' Guides ( https://www.jaguarforums.com/forum/s...-guides-41364/ ) under Miscellaneous - Battery & Battery Charger/Tender
The following 6 users liked this post by GGG:
Constantin FABRIKEZIS (06-18-2015),
den54 (01-21-2016),
Don B (12-12-2016),
JimC64 (10-21-2014),
Joburger (04-19-2016),
and 1 others liked this post.
UPDATES
1. X300 1995 Electrical Guide - JTP476 (thanks to 6sabre)
http://www.mediafire.com/view/fou1yb...e_-_JTP476.pdf
NOTE: if you have a slow internet connection, this PDF is 12.2mB
2. X300 1996 Electrical Guide - JTP508 is available through this link:
http://www.mediafire.com/view/fiqsbb...e_-_JTP508.pdf
NOTE: if you have a slow internet connection, this PDF is 11.4mB
The following 5 users liked this post by GGG:
baddawg (11-09-2014),
Don B (12-12-2016),
Grio (02-03-2015),
JimC64 (11-01-2014),
Orthodixie (04-27-2017)
UPDATES
a) XJ6 Series III - Workshop Manual (thanks to Jose). This is split into 13 sections:
01 General Information
http://www.mediafire.com/view/0mszc2...nformation.pdf
02 Engine
http://www.mediafire.com/view/r1zcdd.../02_Engine.pdf
03 Fuel System
http://www.mediafire.com/view/ifid24...uel_System.pdf
04 Cooling
http://www.mediafire.com/view/fins6i...04_Cooling.pdf
05 Manifold & Exhaust - 6 cylinder
http://www.mediafire.com/view/nfucta...haust-6cyl.pdf
06 Gearbox
http://www.mediafire.com/view/f3xy30...06_Gearbox.pdf
07 Automatic Transmission
http://www.mediafire.com/view/tbm1cc...ansmission.pdf
08 Final Drive
http://www.mediafire.com/view/0p9d6t...inal_Drive.pdf
09 Steering
http://www.mediafire.com/view/q9f5cu...9_Steering.pdf
10 Brakes
http://www.mediafire.com/view/0vbigd.../10_Brakes.pdf
11 Body
http://www.mediafire.com/view/5twa1p...95/11_Body.pdf
12 Heating & Ventilation
http://www.mediafire.com/view/5v8o15...entilation.pdf
13 Electrical
http://www.mediafire.com/view/s21v8w...Electrical.pdf
b) XJ6 Series III - Air Conditioning (thanks to Jose).
http://www.mediafire.com/view/u7odbm...2_Delanair.pdf
02 Engine
03 Fuel System
04 Cooling
06 Gearbox
08 Final Drive
09 Steering
10 Brakes
11 Body
13 Electrical
The following 8 users liked this post by GGG:
autowill (04-22-2016),
den54 (01-21-2016),
Don B (12-12-2016),
JimC64 (05-19-2015),
motorcarman (05-19-2015),
Received 9,009 Likes
XK 150 tech section with 22 pdf files added, see below...
10/17/2016 09:13 PM 2,477,089 2008 MY XK150 Electrical Guide VIN B20075 to B32752.pdf
06/24/2017 02:00 PM 146,067 X150 Electrical Control Modules.pdf
10/20/2016 07:31 AM 68,367,689 2010-2015 MY XK Workshop from B32753.pdf
10/28/2017 03:56 PM 2,631 X150 Issues.xlsx - Shortcut.lnk
10/17/2016 09:17 PM 4,709,944 2009 XK & XKR training Guide 07NP-XKR 10_23.pdf
10/27/2016 09:31 PM 878 Park Brake reset.txt
11/15/2016 10:39 PM 274 Electrical grounds.txt
10/17/2016 09:30 PM 38,831,155 X150 Service manual .pdf
10/17/2016 09:11 PM 3,686,854 2012 XK - X150 electrical guide.pdf
02/19/2017 10:49 PM 3,914,940 2010 MY XK150 Electrical Guide.pdf
10/17/2016 09:54 PM 41,920,508 2006-2009 X150_TSB_Workshop Manual.zip
10/13/2016 10:27 AM 3,868,424 2008 MY Update ALL Vehicles.pdf
10/13/2016 10:03 AM 90,775 X150 (New XK 06MY) PDI MANUAL.pdf
01/16/2012 02:27 PM 42,863,850 2006-2009 X150 - Workshop Manual.pdf
10/13/2016 10:27 AM 44,271,866 NP10 Complete Manual 4-15-09 Jaguar Engine Management NP10-V8JLR.pdf
10/17/2016 09:58 PM 56,643 FL072 Engine control-module (ECM).pdf
10/17/2016 09:15 PM 616,381 2008 XK150 CONNECTOR Quick Reference Guide.pdf
10/19/2016 10:10 PM 31 Useful manual Info.txt
10/17/2016 09:14 PM 2,450,351 2006 MY XK150 Electrical Guide VIN B00379 to B09096.pdf
07/04/2017 02:27 PM 6,972,513 X150 Jaguar Security & Locking Systems #688 688-JAG_10-08-2.pdf
12/26/2016 07:59 PM 468,101 X150 Technical Overview US.pdf
06/24/2017 01:57 PM 85,614 X150 Electrical Network Schematic.pdf
12/16/2016 09:49 PM 4,709,944 2009 XK-XKR Tech Training 09NP-XK 2009XK.pdf
12/12/2016 12:55 PM 3,047 Jaguar Chassis Systems #452 2004 - 2012.pdf - Shortcut.lnk
10/09/2017 11:32 AM 3,922,148 2010 MY XK150 Electrical Guide Job 1.pdf
06/18/2017 08:41 PM 645,705 2010 MY XK150 CONNECTOR REPAIR Guide.pdf
10/17/2016 09:13 PM 2,246,318 2007 MY XK150 Electrical Guide VIN B09097 to B20074.pdf
10/13/2016 10:18 AM 19,508,402 2007 XKR Tech Training 07NP-XKR 10_23 2009XKR.pdf
09/29/2017 09:53 AM 67,911,343 2010 XK150 workshop manual VIN B32753 to B44939.pdf
10/17/2016 09:30 PM 19,508,402 2009 XKR training Guide 07NP-XKR 10_23.pdf
10/17/2016 09:12 PM 3,063,182 2009-2010 MY XK150 Electrical Guide VIN B32753+.pdf
02/19/2017 11:06 PM 83,887 2010 MY XK150 CONNECTOR Listing Guide.pdf
10/13/2016 10:17 AM 38,831,155 X150 Workshop Manual B00379-B32752.pdf
12/19/2016 05:17 PM 2,972 vehicle recovery.pdf - Shortcut.lnk
10/13/2016 10:07 AM 239,812 Hydraulic Roof Manual Operation XK8.pdf
Thanks go to member Hafren
Jim
Jim
Jaguar Forums Editor
Jaguar Press release
08-27-2015 03:18 AM
08-26-2015 05:08 PM
